check engine light finally came on
Old May 10, 2007 | 06:34 PM
89civichb's Avatar
Default check engine light finally came on
I own an 89 stock hatch and as long as I have owned the car the check engine light has never came on. how do i test the ecu to get it to shoot codes out
Old May 10, 2007 | 06:42 PM
stemiched's Avatar
Default Re: check engine light finally came on (89civichb)
if your check engine light is on then your ecu light should be blinking... just have the car on, i assume you know where the ecu is and the light is... just check the light.
if you dont know this is how you read the blinks:
one blink and a pause=10
blinks without pause=1 per blink
meaning: blink____blink___blink_blink_blink
would mean 23
im not even sure if there is a code 23, but thats how you read it.
if you need it here is a list of engine codes and what they mean.
https://honda-tech.com/zerothread/1710584
hope that helps you,
your welcome
jdminspired1's Avatar
Try this man, hope it helps.
https://honda-tech.com/zerothread/1901557
kuks24
Jun 3, 2008 05:33 PM
Project_EK
Aug 13, 2005 04:08 PM
NastyGSR
Oct 8, 2002 11:41 PM
ex_crxer
Apr 6, 2002 07:54 AM
VTECVillain
Jan 6, 2002 11:40 AM
