b16a or b20b
Old May 10, 2007 | 05:35 PM
bustah49's Avatar
Default b16a or b20b
which one is the better motor? b16 is stock and the b20b just has skunk2 intake manifold
Old May 10, 2007 | 05:53 PM
StylishDOHC's Avatar
Default Re: b16a or b20b (bustah49)
they both suck.
Old May 10, 2007 | 05:54 PM
bustah49's Avatar
Default Re: b16a or b20b (StylishDOHC)
the b20b is in muh car now with a gsr tranny that i put together with an ls 5th gear. and it runs good. but not like my old hb i built 3 yrs ago
Old May 10, 2007 | 05:56 PM
ke98248's Avatar
get a b18 bro.
Old May 10, 2007 | 06:21 PM
bustah49's Avatar
Default Re: b16a or b20b (ke98248)
expletive a b18...they are junk.
Old May 10, 2007 | 06:28 PM
black_EM1's Avatar
Community Builder
Community Influencer
How so?
Old May 10, 2007 | 06:39 PM
harryjohnson's Avatar
put the b16 head on the b20
Old May 10, 2007 | 06:45 PM
bustah49's Avatar
Default Re: (harryjohnson)
cant do it with out changing the pistons in a b20b...only a b20z can be lsvtec with no piston change. i do not want to have to spend money for rods and pistons.
Old May 10, 2007 | 06:48 PM
i dont know what to tell you then
Old May 10, 2007 | 08:05 PM
Jedi Jake's Avatar
Default which one is the better motor? b16 is stock and the b20b just has skunk2 intake manifold
well the b20 has an 84mm bore i believe and the ls has an 81mm. if u have the money, resleave an ls to 84mm. i think i read some where that the b20's arent as strong because they individual welds around each cylinder wall.
(i think it said something like that)
Old May 10, 2007 | 09:51 PM
mustang5.slow's Avatar
* B A N N E D *
Default Re: (bustah49)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustah49 &raquo;</TD></TR><TR><TD CLASS="quote">cant do it with out changing the pistons in a b20b...only a b20z can be lsvtec with no piston change. i do not want to have to spend money for rods and pistons. </TD></TR></TABLE>
where did you hear that. what is your resource.?????????
Old May 11, 2007 | 05:38 AM
bustah49's Avatar
Default Re: (mustang5.slow)
for reliabilty...it is not wise to do the swap without new pistons and rods. now sum say it can be done..others say no
Old May 11, 2007 | 07:15 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustah49 &raquo;</TD></TR><TR><TD CLASS="quote">for reliabilty...it is not wise to do the swap without new pistons and rods. now sum say it can be done..others say no
if you want to run cams bigger than itr's then you will need to use new pistons and rods unless you want to take the chance with piston to valve contact. stock b20b pistons are going to give you a low compression anyway so if you want performance it's a good idea to go with something better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustah49 &raquo;</TD></TR><TR><TD CLASS="quote">expletive a b18...they are junk. </TD></TR></TABLE>
that's a really ignorant statement
Old May 11, 2007 | 08:17 PM
JDM_EK4_Coupe's Avatar
(banned)
Default Re: (doood)
JDM B16A FTW I have beaten countless B20, B18C, B18B Swapped vehicles with mine.
Old May 11, 2007 | 08:25 PM
doood's Avatar
Default Re: (JDM_EK4_Coupe)
b16's are overhyped and underpowered
Old May 11, 2007 | 08:28 PM
NOFX's Avatar
H-T White Ops
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">b16's are overhyped and underpowered</TD></TR></TABLE>
Agreed. It has more to do with the gearing of the transmission. Put that B16 transmission on all those other engines and see how they stack up.
Old May 12, 2007 | 08:38 AM
(banned)
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed. It has more to do with the gearing of the transmission. Put that B16 transmission on all those other engines and see how they stack up.</TD></TR></TABLE>
I dunno about that, I still beat B18B's and B18C's w/ a B16 Tranny. Ive driven all sorts of B Series swapped motors and personally I prefer the B16
Old May 12, 2007 | 08:46 AM
phastrthnu's Avatar
make i as frankenstein! b16 head on the b20 block
Old May 12, 2007 | 08:47 AM
Officer's Avatar
Get a D-series.
Old May 12, 2007 | 08:55 AM
Lscivic1999's Avatar
Default Re: (DailyDrivenCB7)
if you dont have plans on building it just get the b16 at least you going to have top end power and a good tranny to get you there...but a really bad low end thought..
Old May 12, 2007 | 09:19 AM
daluv's Avatar
A buddy of mine has an EG hatch. He started out with a B16 with a Skunk 2 Intake manifold, throttle body, Password JDM power chamber CF Intake, DC header, high-flo cat, and a 5 Zigen exhaust. He sold that setup and got a B20Z and kept the B16 tranny, and says he would take the B20Z over the B16 any day. He wishes he started out with the B20Z, a lot cheaper, easy to find, and torquey as all hell!
Old May 12, 2007 | 09:45 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: b16a or b20b (daluv)
x2.
b18b with a light flywheel and a b16 tranny is a good setup. Realiabe torquey, responds well to Boost.
Old May 12, 2007 | 10:18 AM
bustah49's Avatar
Default Re: b16a or b20b (ek forever guy)
i don't like boost..let alone a b18b. boost = problems...problems = money...i am a cheap bastard
Old May 12, 2007 | 10:23 AM
SiRek4
Guest
Posts: n/a
B16 motors are nice. You can beat on them all day and still start it in the morning. Who cares if they dont make alot of power, Fi Single Cams dont make alot of power and that seems to be a trend on Honda-Tech.
Old May 12, 2007 | 12:06 PM
NOFX's Avatar
H-T White Ops
Default Re: b16a or b20b (SiRek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRek4 &raquo;</TD></TR><TR><TD CLASS="quote">B16 motors are nice. You can beat on them all day and still start it in the morning. Who cares if they dont make alot of power, Fi Single Cams dont make alot of power and that seems to be a trend on Honda-Tech.</TD></TR></TABLE>
D-series motors are popular not only because of the potential power they hold, but because:
- They're cheap.
- They're plentiful.
- They're easy to find parts for.
- They're basically bullet-proof.
- They come stock in many of the cars that are running them.
- Some people just have a soft spot for the "under-achiever."
