how do I find my cel wire to check the code??
Old May 10, 2007 | 03:07 PM
christian7750's Avatar
Default how do I find my cel wire to check the code??
I dont see a wire down by the passenger side. if I cant find it how would I check the code? would I use the ecu? need help please
Old May 10, 2007 | 03:08 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: how do I find my cel wire to check the code?? (christian7750)
https://honda-tech.com/zerothread/1901557
Old May 10, 2007 | 03:10 PM
Default Re: how do I find my cel wire to check the code?? (Throwdown)
That doesnt help me locate my wire
Old May 10, 2007 | 03:11 PM
Throwdown's Avatar
how doesn't it??? did you look under there or just feel around?
Old May 10, 2007 | 03:12 PM
I looked under there and felt around and so did two of my friends. Do you know how to check the codes with just the ecu?
Old May 10, 2007 | 03:17 PM
Throwdown's Avatar
look good..it looks like its connected to something but its not ..it holds the jumper plug ...like in the picture the bright green fake connector what kind of car?
well where the hell exactly would it be??
Old May 10, 2007 | 03:18 PM
its a 93 civic
Old May 10, 2007 | 03:20 PM
pdiggitydogg's Avatar
its right near the ecu
under the carpet, passenger side
Old May 10, 2007 | 03:24 PM
Throwdown's Avatar
Default Re: (pdiggitydogg)
mines right above my ecu under the dash ...93 civic si
Old May 10, 2007 | 03:28 PM
Default Re: (Throwdown)
does anyone know how to do it from the ecu?
Old May 10, 2007 | 03:32 PM
boots420's Avatar
Default Re: (christian7750)
i dont think you can do it from the ecu. connector should be on the passenger side kick panel. right above ecu.
Old May 10, 2007 | 03:34 PM
Default Re: (boots420)
if you could take a pic of where it is that would be nice.
Old May 10, 2007 | 03:43 PM
boots420's Avatar
i can do that a lil later today. when i get off of work. 8ish. if you dont find it by then.
alright, thanx
Old May 10, 2007 | 03:44 PM
boots420's Avatar
did ya ever take a look at this link. check the second pic on the page. should look just like that just differ. color.
rizzuto
14
May 17, 2013 07:59 PM
Stunna MIKE
13
Feb 6, 2006 10:43 AM
Tryk
Sep 13, 2004 04:44 PM
c8r9x
Aug 9, 2003 12:16 PM
