**HELP!! My engine still runs even when the ignition is turned of**
Old May 10, 2007 | 02:18 PM
Carpediem291's Avatar
Default **HELP!! My engine still runs even when the ignition is turned of**
Okay, this is something that I have not encountered before. I recently drop a d16 SOHC Vtec in my hatch. I am able to turn on the car just fine. It idles great without bogging, accelerate like normal and it does not throw a CEL. But when I turn the ignition off everything would turn off including my radio but my engine would continue to run and the oil and battery indicator light on my dash remains on. I recently took it to the shop to get the timing and valve adjusted and now it started doing this. What could be the problem???? Thanks in advance
Old May 10, 2007 | 02:29 PM
97Ej6mike's Avatar
you sir, have a possesed car.
Thats the devils work!
Old May 10, 2007 | 02:37 PM
mr_nemesis2003's Avatar
lmao, prob has something to do with your wiring
Old May 10, 2007 | 02:44 PM
97Ej6mike's Avatar
Sounds like a major wiring malfunction. Have that checked at your local mechanic, sounds like you need to have your wiring harness replaced.
Old May 11, 2007 | 04:50 PM
Default Re: (97Ej6mike)
thanks I will try that
Old May 11, 2007 | 05:36 PM
teamsol's Avatar
Default Re: **HELP!! My engine still runs even when the ignition is turned of** (Carpediem291)
alright...did you happen to remove your dash or anything near it that caused you to unplug any wires/connectors? There are two connectors near the iginition that are almost idenitical. It is very easy to confuse one for the other and plug it into the iginition side (this is what is causing your car to keep on running). Many honda guys have had this problem when putting in the jdm climate control..they unplug these connectors then mix them up. This has been covered before with pics explaining how to fix it just do a search. Let me know if that makes sense.
Old May 11, 2007 | 05:50 PM
95DxSi-R2
Guest
Posts: n/a
sounds like an igntion feed circuit is keeping it running, your ignition switch may be bad. how do u get to stop running? bat cable?
Old May 11, 2007 | 06:08 PM
Team RS2's Avatar
Default Re: **HELP!! My engine still runs even when the ignition is turned of** (95DxSi-R2)
did the previous owner ever install a turbo timer? does it have a turbo timer that you dont know about? could have mixed wires up when you removed the dash
Old May 12, 2007 | 08:06 AM
The only way to turn off the engine is to stall on purpose, then unplug my battery connectors to prevent it from using up its juice
Old May 12, 2007 | 08:10 AM
Default Re: **HELP!! My engine still runs even when the ignition is turned of** (teamsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsol &raquo;</TD></TR><TR><TD CLASS="quote">alright...did you happen to remove your dash or anything near it that caused you to unplug any wires/connectors? There are two connectors near the iginition that are almost idenitical. It is very easy to confuse one for the other and plug it into the iginition side (this is what is causing your car to keep on running). Many honda guys have had this problem when putting in the jdm climate control..they unplug these connectors then mix them up. This has been covered before with pics explaining how to fix it just do a search. Let me know if that makes sense.</TD></TR></TABLE>
I never touched my ignition. It was a simple swap, me and my friend took out my ls/vtec set up and drop the d16zc. But I will check this out anyway, I will search for the thread.
Old May 12, 2007 | 08:16 AM
Default Re: **HELP!! My engine still runs even when the ignition is turned of** (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">did the previous owner ever install a turbo timer? does it have a turbo timer that you dont know about? could have mixed wires up when you removed the dash </TD></TR></TABLE>
No turbo was ever installed. Could this be anything to do with my alarm, if I recalled my alarm has a kill switch.
Old May 12, 2007 | 10:47 AM
G0TB00ST's Avatar
From: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
call a priest. you need to perform an exorcism! but to be completely serious, other than if the car is turboed with a turbo timer(which its not) then i dont know what it could be! hope all works out for you
Old May 12, 2007 | 11:58 AM
teamsol's Avatar
Default Re: (G0TB00ST)
try this thread it might help https://honda-tech.com/zerothread?id=209500 this is what i was talking about up top
Old May 12, 2007 | 12:46 PM
Team RS2's Avatar
turbo timers could be installed on N/A cars as well, does your alarm have a kill switch? remote start? or anything igniton related?
Old May 12, 2007 | 01:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">turbo timers could be installed on N/A cars as well, does your alarm have a kill switch? remote start? or anything igniton related? </TD></TR></TABLE>
it does have a kill switch built into the alarm, do you think it's because of that. The thing is I don't recall fooling with it.
Old May 13, 2007 | 08:43 PM
Default Re: (teamsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsol &raquo;</TD></TR><TR><TD CLASS="quote">try this thread it might help https://honda-tech.com/zerothread?id=209500 this is what i was talking about up top</TD></TR></TABLE>
I read this thread and it seems that the guy wired his clock to the hazard thus creating constant flow of power. In my case, I have nothing connected to my hazard. It's funny that it didn't start doing this until I got my timing adjusted. Someone told me that it is possible if the timing is too advanced it may create a backfeed of power to the ignition, is that true??
arusht
May 30, 2010 06:54 PM
bluez6
Aug 27, 2008 08:03 PM
Revolemilbus
Jan 13, 2007 12:32 PM
1QwIkEf
17
Jul 13, 2005 10:31 AM
neiloneil03
Sep 14, 2002 04:28 PM
