96-98 civic power after switch sources.
hello everyone.
i need a different power after switch source for my autometer gauges. its currantly connected to my fuel pump fues :S and i dont wanna keep it that way incase the fues will fall or somthing.
thanks.
thanks.
in the interior fuse block above the fuses there are accessory outputs, you plug in a female quick dosconnect to access them, you'll see what I'm talking about
don't take exactly what those outputs are they may be different, get a DMM
Actually I have the power wires tapped into the cluster power wires so the pods only get power when the key is turned to the on position..... I do also have the pods lights tapped into the factory lighting but where mine are located I'm using the wiring for the hvac controls...
Realdon65
Honda CR-V & Element
Sep 4, 2021 12:15 PM
Vagitarian
Jan 3, 2013 08:55 PM
projektvtec
12
Oct 1, 2005 12:28 PM
jt1583
Jul 10, 2005 06:30 AM
