power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!!
my power locks arent working for some reason. i do have a jdm power window switch in the car so i had to rewire a lil so the master switch would work but im not sure if that would effect the power locks. the car is a civic 4dr 94. thanx
Re: power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!! (hatchi)
i figured out my own wiring but does the power windows effect the power locks??
Re: power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!! (projektvtec)
electrical stuff is tricky. your problem is 90% you messin with the power windows. I say take it apart and study what all you did, compare it to a factory schematic (haynes or helms) but first check your fuses
Re: power locks not working!!!!!!!!!!!!!!!!!!!!!!!!!!! (Philip)
is anyone positive that the power windows effect the power locks?? i have a wiring diagram of both and none of the wires interfere with eachother....and i checked the underdash fuse...are there any other fuses i shuld be aware of??
i checked all fuses unserdash and under hood and they are all fine
if you did the wiring i would check that.. even if you did solder you could have made a cold joint.
90% of all my customers would tell me their computer just stopped working i tell them to just plug it in and 85% of the time i'm right.
humans ??
humans ??
could the power lock control unit be messed up internally for some reason????
Check input from the power door lock control unit. Behind door panel above speaker (ds door).
Disconnect connector: Use a dvom or dmm.
-Check the black wire for continuity with ground. (uses g552).
- connect yel/red to wht/grn terminal, and wht/red to blk momentarily. All doors should lock.
- connect wht/red to wht/grn, and yel/red to blk momentarily. all doors should lock.
Reconnect connector:
-check voltage @ wht/grn (should be 12v)
-move drivers power door lock switch to lock and check for voltage @ grn/wht (should be 1v or less)
-move drivers door lock switch to unlock and check voltage @ grn/red (1v or less)
- drivers door lock **** to lock position and check voltage @ blu/wht (1v or less)
Check back and let me know.
Beegee208080
06-11-2012 08:09 AM
95excoupe
03-09-2003 12:04 AM
