Yet another Rough Idle -- searched!
Recently my car has started having a very rough idle. It sounds like "clattering" if that makes sense. It doesn't have that purr, instead it is very rough and metallic sounding. I've found if I put in the clutch while idling, the sound goes away. This is seperate from a surging idle (another problem I have, but know how to deal with). My car has 158xxx miles on it, recent oil change, tightening of timing belt, radiator flush, tranny flush. What could cause this? Any ideas?
One thing that has changed on my car is that my muffler was taken off and put back on my car....is it possible if the bolts aren't tight enough that an exhaust leak could cause this?
Thanks in advance
Thanks in advance
i've got a similar problem. cleaned the Idle air valve and throttle body, but all taht did was make it more consistent so I'm going to clean the fast idle valve and drain the coolant next.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMelt4 »</TD></TR><TR><TD CLASS="quote">I've found if I put in the clutch while idling, the sound goes away. </TD></TR></TABLE>
Does the idle smooth up when you disengage the clutch (along with the sound going away)? That's a datapoint - I'd look at that first.
PM
PM
