**Ticking noise** (Only when given throttle and not at Idle)
Old May 10, 2007 | 08:03 AM
Fighterinsnatch's Avatar
Default **Ticking noise** (Only when given throttle and not at Idle)
Car is running like ****, no power. I've replaced spark plugs, wires, o2 sensor, header, pcv valve, and checked the timing (dead on).
I used to hear the ticking before the car warmed up, but now I hear it all the time when driving. If I put it in 5th gear and floor it its really loud.
Just to note, I just replaced the header and o2 sensor. I hope its not a small leak, but I'm sure it would sound different.
Old May 10, 2007 | 08:13 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: **Ticking noise** (Fighterinsnatch)
Sounds like you need a valve adjustment.
$100 at any honda dealer or DIY. Not that hard.
Old May 10, 2007 | 08:25 AM
mistahmac's Avatar
sounds like you need to check your valves.
Old May 10, 2007 | 08:27 AM
d3vilishSi's Avatar
Default Re: **Ticking noise** (mistahmac)
Could be LMA's also, but I don't know if that would cause power loss......
Why would'nt it tick loud when i'm at a stand still and reving?
Old May 10, 2007 | 08:29 AM
jummpmann's Avatar
probably need a valve adjustment. How long has it been doing this?
Old May 10, 2007 | 08:51 AM
Default Re: **Ticking noise** (Shafinkalyan)
well it used to tick a little bit when i first started the car ( for about 6 months) Its been doing the really loud tick for a couple of days.
I have had a problem with low end power since I did the swap. I've replaced nearly everything.
Old May 10, 2007 | 09:44 AM
Ek Forever y0!
Yeah, a valve adjustment is probbaly in order regardless of whether ot not that's whats making the noise. Just do that and if it doesnt fix it, mark it off your list of potentialities.
Process of elimination.
Old May 10, 2007 | 10:04 AM
eg_93's Avatar
hey dude have u checked ur rod bearings beacuse that happened to me the same way, i changed everything and adjusted my valves and it ended up being that i spun a rod bearing
Old May 10, 2007 | 11:24 AM
Default Re: (eg_93)
how do you check for this?
Default Re: (eg_93)
also is this something that you can fix yourself?
Can someone please explain why I would only hear it when I'm actually driving?
Old May 10, 2007 | 12:12 PM
Bump
Old May 10, 2007 | 12:50 PM
eg_93's Avatar
to tell u the truth i have no idea but when that happened to me i could only hear it when i drived then it got worse
and to check it u have to take off the oil pan if u dont know how i dont think you should do it ur self
DarkoEK9
Honda Civic (2006 - 2015)
Dec 31, 2013 06:06 PM
Mister V
Oct 3, 2008 11:30 PM
vdawg559
Jul 20, 2008 02:15 AM
92ehatch
Feb 3, 2006 10:47 AM
ls-t del sol
Sep 16, 2003 08:14 PM
