prelude seats in a eg?
Wow this post is back from the dead lol.
Yep the fronts fit right in, I bolted them up to my stock eg rails. 1000% better looking than stock seats. Here's a pic.
Not sure about the back's... I would also like to know if anyones tryed the back seats. The bottoms look like integra bottoms but I'm thinking the back upper wont work unless you got a 2/4 door and wont work for hatchbacks.
I recently put 96 lude seats in my ej8. Not quite the same thing, but the install may be similar.
I took my stock seats and the prelude seats completely apart in order to try to find the best way to do the swap.
Swapping the seat pans was a no go. The prelude pans are longer and wider than the civic pans. Civic pans didn't fit for **** on the prelude foam. Plus I think there were other issues with bolting on the prelude back rest. I can't remember exactly.
I ended up taking the outboard (closest to the door) seat rail off of the civic seat and using it as the outboard rail on the prelude seat.
I reused the existing rail closest to the center console from the prelude seat. The holes do not line up with those on the floor. I ended up elongating the mounting holes on the rail and welding on these fat *** washers. the holes in the washers are the new seat bolt holes. Hard to explain and I don't have a picture.
Some issues with prelude seats...
Prelude seats are super comfy!!
Lude seats sit low to the floor. I am guessing at least an inch lower than stock seats, probably more. It took some getting used to.
Lude bolsters stick way out - this is cool because they hold you in the seat good, bad because your *** scrapes all over them when you climb in and out. I suspect my bolsters will wear quickly as a result.
My center console lid rubs on the inside bolsters of both seats. Again, the lude seats are larger - both wider and longer - than my stock civic seats
The colors kind of suck. I have black, which in certain light looks blue-ish or purple-ish. The other option is blue.
Overall I like them. The best way to put them in I think is just to get the seats and go for it over a weekend.
Modified by jibs at 7:38 PM 7/16/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Comfy?</TD></TR></TABLE>
Yeah I like how the bottom seat adjusts up/down. Overall, I love how they look, their just as comfy as my old EG's, with more adjustability, and originality than integra seats.
Prelude 5g seats FTW!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jibs »</TD></TR><TR><TD CLASS="quote">I recently put 96 lude seats in my ej8. Not quite the same thing, but the install may be similar.
I have heard the 4g's install is a lot harder than what my experience with my 5g's was. Mine was pretty straightforward.
I received no seat pan with my 5g's (when I bought them for $50
), so I just ripped my old EG rails and bolted them straight up to the 5g's. It was just a bolt off/on (no modification required) affair which was fairly easy, accept I ended removing them and putting them back on about 5 times because of bolts I forgot to put on in the first place.. The install took me about 2 1/2 hours, from taking my stock seats out and putting the 5g (1999) prelude seats in.
But one problem I have is when I adjust the bottom seat is adjusts one side more than the other side, so it becomes real crooked when I adjust it way down or way up.
</TD></TR></TABLE>I have heard the 4g's install is a lot harder than what my experience with my 5g's was. Mine was pretty straightforward.
), so I just ripped my old EG rails and bolted them straight up to the 5g's. It was just a bolt off/on (no modification required) affair which was fairly easy, accept I ended removing them and putting them back on about 5 times because of bolts I forgot to put on in the first place.. The install took me about 2 1/2 hours, from taking my stock seats out and putting the 5g (1999) prelude seats in.But one problem I have is when I adjust the bottom seat is adjusts one side more than the other side, so it becomes real crooked when I adjust it way down or way up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmeracer »</TD></TR><TR><TD CLASS="quote">good to know. So you think the bottom part will fit, but not the top part of the back seat?</TD></TR></TABLE>
Yes, thats what I'm thinking, but I'm not 100% sure. Anybody on HT had any 1st hand experience with prelude backs fitment in an EG?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">those look clean... I like the thread pattern that they have
Thanks
me too.
I like the 5g's seats shape and thread pattern. I loved them in my old lude, and I had to have a pair for my hatch. I was just so happy that I could pick them up for 50$ in mint condition.
</TD></TR></TABLE>Thanks
me too.I like the 5g's seats shape and thread pattern. I loved them in my old lude, and I had to have a pair for my hatch. I was just so happy that I could pick them up for 50$ in mint condition.
g35silversurfer
Dec 17, 2010 03:47 PM
AlwayzSpoolin
13
Sep 17, 2007 07:26 PM
HatchiHatch
13
Jun 4, 2005 11:03 AM
