Broke Valve cover stud
Old May 9, 2007 | 09:26 PM
invisible's Avatar
Default Broke Valve cover stud
Will it be find to drive untill I can get another one? Any oil leak?
pic from liftedresearchgroup...
Old May 9, 2007 | 09:27 PM
Mr.EM1_EK's Avatar
Default Re: Broke Valve cover stud (cheesee)
you should be fine, its only one right?
Old May 9, 2007 | 09:29 PM
invisible's Avatar
Default Re: Broke Valve cover stud (Mr.EM1_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK &raquo;</TD></TR><TR><TD CLASS="quote">you should be fine, its only one right?</TD></TR></TABLE>
Yeah, just that one I circled.
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Ah the old paint the valve cover and then break off the stud routine. You will have an oil leak. What i did was silicone the metal/rubber washer into the valve cover to minimize how much oil I lost while i waited for the replacement. You have to order the replacement from honda.....MAKE SURE THEY ORDER THE RIGHT ONE. make sure you point at the computer screen for the parts guy. I know the parts guy, a porter, and a few techs personally at my dealer...otherwise I would be totally un trusting.
You could also try going to a junkyard with your part in hand and matching parts from different cars.
Phil DeVtec's Avatar
You'll be alright.
Old May 9, 2007 | 09:31 PM
B serious's Avatar
Default Re: Broke Valve cover stud (Phil DeVtec)
wait...did you just break off the very very top that holds on the spark plug cover? Cuz if thats all you broke, you'll be fine. I retract my earlier statement in that case.
Old May 9, 2007 | 09:43 PM
invisible's Avatar
Default Re: Broke Valve cover stud (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">wait...did you just break off the very very top that holds on the spark plug cover? Cuz if thats all you broke, you'll be fine. I retract my earlier statement in that case. </TD></TR></TABLE>
it snapped right about the washer. well put some hondabond around anyways just incase lol...
Modified by cheesee at 9:38 PM 5/12/2007
Old May 9, 2007 | 10:14 PM
invisible's Avatar
Are all b-series ones the same?
Old May 10, 2007 | 04:09 AM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesee &raquo;</TD></TR><TR><TD CLASS="quote">Will it be find to drive untill I can get another one? Any oil leak?
Old May 10, 2007 | 05:26 AM
d3vilishSi's Avatar
Mine is broke in the same spot and I have no oil leaks or anything....it'll be fine.
Old May 10, 2007 | 05:41 AM
invisible's Avatar
Default Re: Broke Valve cover stud (d3vilishSi)
yeah just drove, no leaks. still have the hondabond on there tho..
Shaguar47
Feb 11, 2005 06:28 PM
ITR_1211
29
Dec 24, 2003 08:15 AM
jweller
Oct 15, 2003 04:50 AM
TeamTooQuick
May 21, 2002 05:23 PM
