overheating or not overheating?
Old May 9, 2007 | 06:14 PM
91ed9's Avatar
Default overheating or not overheating?
yeah so i just got my car back oin the road i got a 91 crx with a b16a and an eg rad with a slim fan!
now i had this for a while but for some reason now my resevoir tank is bubbling and then over flowing all over the place but nothgin is coming out of the radiator and the car is not overheating!!!
idk what is wrong, do you think maybe the rad is bad? but like i said ive had the rad in there for a while and thsi never happened !
Old May 9, 2007 | 06:15 PM
Suck my DX's Avatar
Default Re: overheating or not overheating? (91ed9)
is your fan turning on?
Old May 9, 2007 | 06:17 PM
91ed9's Avatar
Default Re: overheating or not overheating? (Suck my DX)
yeha its on a manual switch also and its running all the time really
edit" do you think it could be the thermostate not opening all the way?
Modified by 91ed9 at 10:28 PM 5/9/2007
Old May 9, 2007 | 07:01 PM
91ed9's Avatar
bump
Old May 9, 2007 | 07:07 PM
pandarex's Avatar
check your radiator cap. its suppose to let fluid both to and from the resivoir, it might just let it there and not back. there real cheap and might as well replace it since it probably never has been replaced
Old May 9, 2007 | 07:34 PM
91ed9's Avatar
Default Re: overheating or not overheating? (pandarex)
hmm... i will try that
anyone else have any input if the cap doesnt work?
Old May 10, 2007 | 02:51 PM
91ed9's Avatar
we're good! i changed the thermostate and rad cap (the cap was fucked up)
no overflowing since then! thanks for the help guys
Old May 10, 2007 | 04:51 PM
Crx Jimmy's Avatar
yes it was most likely the cap, my old dx had a bad cap and it would boil over but not overheat, with the new cap it raised the boiling point and was fine
Old May 10, 2007 | 04:54 PM
91ed9's Avatar
Default Re: overheating or not overheating? (Crx Jimmy)
yea, now my alternator isnt charging the battery
im tired of this
fuglybutruns
Jul 28, 2015 07:50 PM
x justin
Feb 17, 2015 05:02 PM
chuniepatuni
Dec 5, 2006 07:09 PM
jrzy2nR
13
May 4, 2006 09:47 AM
menappi
Feb 3, 2005 01:23 PM
