ok seriously need help with starter issue.
Old May 9, 2007 | 05:59 PM
littlebill's Avatar
Default ok seriously need help with starter issue.
i have a b-16 and i was having trouble with my starter so i put a new one in. it worked for about a day and it stopped working, i took it back got a new one and still i have nothing as far as any luck starting the car, i cant even get the starter to engage, nothing happens at all when the key is turned. oh and yes the battery is good its brand new and i just had it checked. any help or ideas would be awsome. thanks in advance.
Old May 9, 2007 | 06:01 PM
Suck my DX's Avatar
Default Re: ok seriously need help with starter issue. (littlebill)
have you tried hitting it with a hammer?
sounds like a bad connection at the fuse box....
Old May 9, 2007 | 06:02 PM
littlebill's Avatar
Default Re: ok seriously need help with starter issue. (Suck my DX)
checked all the fuses and such.
this really is starting to suck
Old May 9, 2007 | 06:10 PM
littlebill's Avatar
any one else have any ideas?
Old May 9, 2007 | 06:15 PM
Slurp56's Avatar
There isnt a starter fuse, so its not a fuse problem.
As basic as this sounds, try removing both battery terminals, cleaning them, and reinstalling them. Then make sure the power wire on the starter is secure and also the starter solenoid wire is not corroded and is making a good connection. Lastly, check the negative battery terminal wire, where it bolts to the transmission. Make sure that bolt didnt loosen up and that its making a good connection.
If all of those things test good, then use a voltmeter on the starter solenoid wire and have a friend turn the key to the cranking position. Measure for 12V. If 12V is not present, start investigating the ignition ball switch.
Old May 9, 2007 | 06:22 PM
Suck my DX's Avatar
Default Re: ok seriously need help with starter issue. (Slurp56)
yeah there is no starter fuse, but one of those large fuses in the underhood fuse box will make the car not start as well....i blew it on my old ef and the starter wouldnt even click....changed it and it worked like before...
Old May 12, 2007 | 01:15 AM
votoms888's Avatar
I am having the same problem. I replaced the starter last week and was fine. It stopped working again tonight. All I did was tap it and it stared working. What does the shock do that makes it work? Solution?
Old May 12, 2007 | 04:26 AM
t25d16a6's Avatar
Default Re: ok seriously need help with starter issue. (votoms888)
if u have to hit it to get it to work the solution is a new starter...or u can just replace the brushes and see if it fixes it
Old May 12, 2007 | 09:19 AM
gotbooost's Avatar
was your new starter from a junkyard or was it reman from an auto parts store? if it's reman maybe you should take it in and have them test it. only takes you 10 min to yank that thing out.
Old May 22, 2007 | 02:09 PM
Its me DUB's Avatar
Default Re: ok seriously need help with starter issue. (gotbooost)
I'm having the same exact issue. I tested current on the ignition switch under the dash and that's fine, battery volts fine, starter is getting power, all grounds tightened, all fuses checked and still nothing. We then took off the test wire from the voltmeter and bridged from the battery to the starter and the car would crank and start right up. But if I try at the key, there's nothing. Going to check out the clutch switch tomorrow.
Modified by doitdub at 4:11 PM 5/22/2007
tvdc2
Jul 29, 2016 08:48 AM
liam.delucia
May 4, 2016 06:08 PM
mdrouillard1983
Jun 6, 2014 05:24 PM
karatekid1981
May 18, 2007 09:21 PM
zhan28
Mar 8, 2006 04:54 PM
