URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF
Old May 9, 2007 | 02:19 PM
madlion's Avatar
Default URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF
you know when you take your spark plug cover off. I took the cover off and the bolts that secure the cover came off but the bolts under that were a little loose i tightened one too tight and it snapped it off. just one bolt broke off. how bad did i damage my car?
http://i4.tinypic.com/4otj33b.jpg
thanks in advance
Old May 9, 2007 | 02:20 PM
madlion's Avatar
Default Re: URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF (madlion)
the top left bolt is the one with the issue
Old May 9, 2007 | 02:22 PM
mafia's Avatar
its still drive able.... Go to a dealer and buy one. (you will need to take off valve cover in order to change it (and a deep 10mm or 12mm not sure)
Old May 9, 2007 | 02:24 PM
madlion's Avatar
Default Re: URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF (mafia)
how long can i drive like that. i have to get it inspected this month could i go a week or two?
Old May 9, 2007 | 02:29 PM
madlion's Avatar
also i work a lot i dont really have time to do this.. how much do you tihnk a shop would charge me.. an hours worth of work? i dont see it taking much longer then that
Old May 9, 2007 | 02:37 PM
Jizzmaster Zero's Avatar
(banned)
You can't even fix that? You suck at life.
Old May 9, 2007 | 02:57 PM
madlion's Avatar
Default Re: URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF (Jizzmaster Zero)
my time is more valuable working at my job then repairing cars. im not in college anymore homeslice. eventually when i retire i will return to working on my own vehicle when i can afford a garage and a lift and air tools.
id rather do what im good at now and use the tools i have, rather then wrenching the ride and working on a hot engine over torqueing bolts.
do you wana get off my ***** now? i hope so flamer
i posted a pic and biches still wana flame..
Old May 9, 2007 | 03:04 PM
vlc92189's Avatar
dude.. they break all the time.. it takes seriously 5-10 mins at most.. pull valve cover off take bolt off. torque new one on.. not hard.
Old May 9, 2007 | 03:14 PM
madlion's Avatar
Default Re: URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF (vlc92189)
what if it needs to be drilled and tapped???
Old May 9, 2007 | 03:16 PM
Luserkid's Avatar
Take off your valve cover completely and youll see how easy it is to repair.
Old May 11, 2007 | 03:21 AM
vlc92189's Avatar
lol.. it dont.. look. when you take the valve cover off.. its also screwed into the head. just take a 10 mm socket, unscrew it. torque new one down, and thats it.
Old May 11, 2007 | 03:30 AM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madlion &raquo;</TD></TR><TR><TD CLASS="quote">also i work a lot i dont really have time to do this.. how much do you tihnk a shop would charge me.. an hours worth of work? i dont see it taking much longer then that
honestly.. it would be cheaper/easier/faster for you to goto honda and get one and do it urself then it would be to take ur car somewhere... drop it off with part.... hope they dont bitch an try to smooth u into buyin 10 other things... then get an ugly bill, when u could have just took 5 minutes outta ur life, popped off cover, unbolt old broken bolt, install new one, v/c back on, put nut on secure but not to tight, ur done...
on a lightened note, you could just dab some gasket maker or something around the top of the hole to make sure no oil comes outta there, thats what i did for a fix until a couple days later when i did the job the right way and in under 10 minutes and 10 bucks lol..
Old May 17, 2007 | 11:29 AM
JMelt4's Avatar
Default Re: URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF (JDM_SOHC)
I have the same problem with a stripped bolt. I have a D15B7 (the valve cover to the right).....and I can't tell what bolt I need! Which number? Is it 15 or 16 (even though that's not my valve cover)?
Old May 17, 2007 | 12:12 PM
JMelt4's Avatar
Default Re: URGENT NEED HELP SPARK PLUG VALVE COVER BOLT BROKE OFF (JMelt4)
bump for answer
Old May 17, 2007 | 01:12 PM
JMelt4's Avatar
up up up
Old May 17, 2007 | 01:56 PM
fdavie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMelt4 &raquo;</TD></TR><TR><TD CLASS="quote">
I have the same problem with a stripped bolt. I have a D15B7 (the valve cover to the right).....and I can't tell what bolt I need! Which number? Is it 15 or 16 (even though that's not my valve cover)?</TD></TR></TABLE>
14 on the right looks like the stud that the bolt goes into....
moonleyet
May 1, 2010 02:50 AM
SkoundrelUSA
11
Feb 7, 2006 04:46 PM
red_ek_hatch
Mar 31, 2005 12:21 PM
reeder321
16
Mar 11, 2004 04:28 PM
R.S.
May 21, 2003 05:56 PM
