turbo question
so im bolting on my turbo kit on saturday and as of rite now i have 140hp, im only planning on running 7psi off a te04h max for rite now im wondering if that will put me close to 200hp it has got a cam, intake, etc im also running bigger injectors i have a friend with a neon with the same turbo and 7psi and it runs really low 14's so im lighter and more done so... idk any info is welcome.
thanks
kyle
thanks
kyle
what type of fuel management are you going to be running. If you dont have any type of fuel management i wouldnt suggest you run anything more than 6 psi, you could run your car lean and cause some serious damage
sounds like http://www.homemadeturbo.com might be a good resource for you, and i hope you went with the DSM 450's
yes i did (larger injectors) im also going to adjust the timing accordingly, so i dont get detination or anything i honestly thing the 7psi will be fine for now its a rebuilt motor will see what happens saturday.
good luck.. i remember when i made my first turbo kit (10 years ago) i was so impressed with the power it made (7 psi)..i ran dsm 310cc 's with a fmu and it ran better than the 450cc's so if you are running extremely rich give this a try....
how much bigger are acura injectors compared to stock d15b1 injectors also i think i might use the pr4 ecu( ls) because that will give me more gas( seeing how its for a 1.8)
also how do i hook up the map check valves i dont want a cel....
