Moving home from school permanently sale
I'm home now in NH, organised most everything... but I still want to get rid of it!
3 PM6/5 heads
D series alternator, brand new NAPA reman
4 D series starters
6 PM6 pistons
3 P28 pistons
all pulleys and sensors out of A6 block
box of motor mounts and brackets
4 D series water pumps, all in good working condition but used
d16a6 throttle body (no TPS)
B18A throttle body (no TPS)
underhood fuse box
D series timing cover
2 thermostat housings with working thermostats
88 Si tranny
90-91 Si tranny, needs input shaft bearing which I have, I can put it in if you want. could probably use new seals while I'm in there.
head bolts (2 sets)
D16A6 crank pulleys (2)
DPFI dizzy
D15 ACL rod bearings
3 13x8 4x114 aluminium 2-piece wheels, with 5 Hoosier c3000 RR slicks
Civic Si dash
Y8 ignition control module, new
Nokia phone datalogging cable (can solder into the ECU for datalog)
2 D16A6 crankshafts, one needs a regrind, the other is fine
D16A6 main girdle
A6 oil pickup thing
DSM SMIC
D16/D15 oil pan
CRX Si OEM rear springs
DA driver side axle (good for B swaps), new/reman autozone
rear upper plastics (the triangles that go around the rear windows)
KKK K26 turbo off a Porsche 944 turbo, I believe the flange is the same as a T3
CRX Si rear OEM sway bar
CRX Si sunroof assembly
for small stuff of little or no value, I'm willing to trade for junk (read: DX, STD, HF, etc) OBD0 or possibly obd2 ECUs, I need more for making conversion harnesses.
Added some pics:
DA axles, one is missing (shouldn't leave stuff at the shop):
DA throttle body:
Civic dash:
Rear plastic:
EACV for A6 manifold (I don't know why I have this pic and not the other stuff in the box with it):
one of the valve covers, sandblasted:
Wheels and tires, someone before me tried to cut one of the tires off, I didn't get this side off yet because I can't get the bead to break on the tire machine:
You can see all the parts on the shelf in that last one too, I'll open the boxes up and get the rest of the pics soon.
Modified by downest at 1:01 PM 5/18/2007
Modified by downest at 1:03 PM 5/18/2007
3 PM6/5 heads
4 D series starters
6 PM6 pistons
3 P28 pistons
underhood fuse box
88 Si tranny
head bolts (2 sets)
DPFI dizzy
Civic Si dash
D16A6 main girdle
A6 oil pickup thing
DSM SMIC
D16/D15 oil pan
Added some pics:
DA throttle body:
Civic dash:
Rear plastic:
<FONT SIZE="18">
UPDATE MORE PICS</FONT>
[imghttp://rpi.edu/~downest/Pics/parts/fusebox%20open.jpg][/img]
Modified by downest at 1:02 PM 5/18/2007
my SOHC VTEC head is for sale too, complete with goodies:
https://honda-tech.com/zerothread?id=1988294
Alexpbnj
Nov 14, 2010 12:51 PM
itr1235
Jun 26, 2004 08:11 PM
