Throttle body noise
Old May 8, 2007 | 05:42 PM
rsf-g's Avatar
Default Throttle body noise
i have a 97 coupe all stock, the throttle body makes this whistling noise. i took of the intake to see if that was causing it but it still does. it only makes noise if i floor it or if i hold the gas pedal at certain levels. thanks in advance for all your help.
Old May 8, 2007 | 05:48 PM
t0p_sh0tta's Avatar
Default Re: Throttle body noise (rsf-g)
Sounds like turbulence to me. Try cleaning it.
Old May 9, 2007 | 05:16 AM
Crispy's Avatar
Default Re: Throttle body noise (t0p_sh0tta)
X2
Old May 9, 2007 | 06:27 AM
pumatec8's Avatar
sometimes the throttle plate is a little out of position from the factory. this will cause a little whistling noise at a certain rpm. i wouldn't worry about it unless it is really annoying to you.
Old May 9, 2007 | 01:30 PM
rsf-g's Avatar
Default Re: Throttle body noise (pumatec8)
it actually is annoying
ill clean it out and see if it makes a difference
thx for your comments
Old May 9, 2007 | 02:22 PM
rsf-g's Avatar
well i just got done cleaning it (top and bottom of plate)and drove around the block. noise was reduced but still some there.
Any suggestions??
civicgsr116
Nov 22, 2007 08:47 AM
rsf-g
Oct 2, 2007 05:42 PM
sslude
Feb 17, 2003 05:14 PM
crxtreme27
Aug 31, 2002 11:49 AM
