air coming out of intake manifold....
i have a newly rebuilt gsr motor and i think i messed up the timing. also, when it starts and runs, when i step on the gas, it almost stalls and like coughs air out of the intake. is it possible that i bent an intake valve by running the car with the incorrect timing??
backfiring through the intake is USUALLY a sign of misfiring. intake valve is opening on exhaust stroke or compression stroke. double check your timing.
yes it could be possible a valve could be bent. how bad, i'm not sure.
what i would do is get your timing back to spec and perform a compression and leakdown (if you have shop air) tests. that should determine if you damaged your valvetrain and what cyl. if so is damaged.
i did out the timing back to spec. and it actually ran a little bit better after but it still coughs back through the intake when you hit the gas. also, can you do a leakdown test with the head on the car???
A leakdown test requires that the head is still on the car.
http://www.c-speedracing.com/howto.php
You can try the compression test as well. Have you adjusted your valves? If they are too tight (not fully closing), it could cause your symptoms.
ok i did a compression test and these are the results....
cyl 1 - 0 psi actually it was less than 10
cyl 2 - 210 psi
cyl 3 - 190 psi
cyl 4 - 200 psi
is there a way to test and see if there is a valve stuk open???
cyl 2 - 210 psi
cyl 3 - 190 psi
cyl 4 - 200 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoB316 »</TD></TR><TR><TD CLASS="quote">ok i did a compression test and these are the results....
cyl 2 - 210 psi
cyl 3 - 190 psi
cyl 4 - 200 psi
is there a way to test and see if there is a valve stuk open???</TD></TR></TABLE>
Try adjusting your valves. Cylinder 1 may be adjusted too tightly, which would cause the valve(s) to remain open.
cyl 2 - 210 psi
cyl 3 - 190 psi
cyl 4 - 200 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoB316 »</TD></TR><TR><TD CLASS="quote">how do you do a valve adjustment???</TD></TR></TABLE>
http://www.c-speedracing.com/h...t.php
A tool like this helps immensely with a B-series VTEC head.
http://www.amazon.com/Alltrade...r=8-2
clicky79
Nov 22, 2018 03:41 AM
slow4dr
Feb 2, 2009 08:16 PM
nuclearhappines
Jan 4, 2006 07:03 PM
