PIC Performance LCA vs. Koni Yellows
So yesterday I finally decided to put the new suspension setup on (Koni Yellows/GC's) along with PIC Performance LCA's. I ran into a HUGE problem with the combination. The Koni strut will not fit onto the LCA. The bushing in the LCA is about a 1/4 of an inch to long on both sides. Has anyone encountered this problem? What do I do? Do I shave the bushing down so that the strut has enough room to slip on to?
Let me remind you that the LCA's are not the newer version with the spherical bearing.
http://picperformance.com/stor...t=108
You might have gotten the wrong lca, i know that the bushing thickness on the lca where the strut bolts is different between eg and ek, though I can't remember which is thicker (I think eg is thicker).
This would be my guess, though a quick pm to the PIC guys would be a good idea
the EG rear LCA's shock bushing is in fact wider than EK.
BUT, EG and EK rear LCAs are not swapable. The EKs rear LCAs are longer.
It sounds like you have an EG with EK lower shock mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">why are you asking us?
talk to the PIC guys</TD></TR></TABLE>
Well I was hoping tht they would of seen this thread and replied, but since you've been so helpful with your post why bother?
BTW this is a technical question thats why I asked Captain Obvious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude »</TD></TR><TR><TD CLASS="quote">You might have gotten the wrong lca, i know that the bushing thickness on the lca where the strut bolts is different between eg and ek, though I can't remember which is thicker (I think eg is thicker).
This would be my guess, though a quick pm to the PIC guys would be a good idea </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">the EG rear LCA's shock bushing is in fact wider than EK.
It sounds like you have an EG with EK lower shock mounts.</TD></TR></TABLE>
Thanks guys this was helpful compared to the douche bag above.
I had it taken care of. I just milled the bushing down to the correct width. They were for an EG (which I have) but it seems like they were made for the stock shocks or anything else other than Koni because they slipped right in. But anyways, I got everything mounted up properly. Thanks fella's!
BTW this is a technical question thats why I asked Captain Obvious.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97ShLude »</TD></TR><TR><TD CLASS="quote">You might have gotten the wrong lca, i know that the bushing thickness on the lca where the strut bolts is different between eg and ek, though I can't remember which is thicker (I think eg is thicker).
just incase you're curious... the EK bushing is 40mm wide, the EG is 50mm wide.
sounds to me like it's an issue with your konis not the LCAs.
glad to hear you have access to a mill and got it taken care of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">i saw those fruity lca's and always wondered who made em.
stars are so cute, i hope they make some with unicorns next!</TD></TR></TABLE>
Thats why I bought them... I couldn't wait for the Unicorns to come out.
Fruity or not they still function better than any stock EH LCA.
P.S. I saw your name on the waiting list for the unicorn versions with spherical bearings, but I won't tell anybody on here!
da9pwnsu
Jul 30, 2006 04:13 PM
