Very bad vibration
When i turn left or go over big bumps my car vibrates violently, the harded i turn left the more violently the vibration. I replaced the axle and it didnt help one bit. Could it be my suspension?
Any help or suggestions is really appreciated i want this fixed.
Thanks
Thanks
Wow that was so undescriptive.
How about the year make and model. Then how about if you have a swap, mounts, things of that nature.
My guess, worn tie rod end, worn suspension bushings, blown shock, bent LCA, cheap mounts.
Has it always done it, is it new? What happened or sounds it made when it started?
AllmotorGSReg
May 3, 2010 09:14 AM
