97-98 ITR's have different Cam's???? then 2000-01
Old May 30, 2002 | 11:05 PM
Mr.Fairlady's Avatar
Default 97-98 ITR's have different Cam's???? then 2000-01
whats up w/ that.Are the 97-98's slower the 2000-2001,.. or make up for it somewhere else?(CW hahaha)?
Was curious,.if so,..its easy as swapping cams then,. correct, to regain or even increase power?
Old May 30, 2002 | 11:09 PM
Yellow Dragon's Avatar
Default Re: 97-98 ITR's have different Cam's???? then 2000-01 (MR.K20)
No... not this debate again!
In a nutshell, the '97-'98 ITRs didn't come with A/C stock. It was believed that the '00-'01 ITRs had a slightly higher lift intake cam to compensate for this and the increased emissions on the newers ones.
[Modified by Yellow Dragon, 2:10 AM 5/31/2002]
Old May 30, 2002 | 11:21 PM
SurferX's Avatar
Default Re: 97-98 ITR's have different Cam's???? then 2000-01 (Yellow Dragon)
It's 3 degrees extra duration on the intake cam whoopee. If I was going through the trouble of upgrading cams on a 97-99 R I would probably get something a little more worthwhile.
STOCK 1997-1999 ITR profile
INTAKE lift - 11.5 mm,duration - 240
@1mm
EXHAUST lift - 10.5mm, duration - 235 @1mm
STOCK CTR and 2000-2001 ITR profile
INTAKE lift - 11.5 mm,duration - 243
@1mm
[Modified by SurferX, 12:21 AM 5/31/2002]
Schister66
Apr 9, 2007 02:11 AM
c1civic
14
Feb 3, 2004 08:42 AM
vtecdc2
Sep 2, 2002 07:52 PM
hybridreams
Feb 1, 2002 06:58 AM
garados
Jan 30, 2002 05:04 PM
