Is the b16 and b18 timing belt the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zach1288 »</TD></TR><TR><TD CLASS="quote">ok then this guy has no idea what he is selling haha
One more question when i do the timing belt im doing the water pump also should i do the tensioner ?</TD></TR></TABLE>
yes, when doing the timing belt, it is wise to do the water pump, tensioner, and if you can the cam seals.
One more question when i do the timing belt im doing the water pump also should i do the tensioner ?</TD></TR></TABLE>yes, when doing the timing belt, it is wise to do the water pump, tensioner, and if you can the cam seals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsir »</TD></TR><TR><TD CLASS="quote">b18 belt is longer due to a b18 having a taller deck height</TD></TR></TABLE>
correct. you need a belt to match the block and water pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 »</TD></TR><TR><TD CLASS="quote">Not to threadjack but i can use a b16 waterpump and gsr timing belt on my b20vtec right?</TD></TR></TABLE>
all b series vtec water pumps are the same. and yes on the belt.
2camsaam
Jul 30, 2003 12:20 PM
