what radiator on an ef civic hatch?
Old May 7, 2007 | 09:28 PM
Jdmsolutions's Avatar
Default what radiator on an ef civic hatch?
hi i was just wondering what radiator you guys are using on your ef hatches.... i tried to install an eg single core tonight and there was alot of bending of the front crossmember to be done.. so i jsut stopped to get some imput... im going to be using a drag gen 3 manifold and to4e... wasnt sure what would cool good enough... thanks guys.. mostly guys with stock front crossmember!!
Old May 8, 2007 | 09:31 AM
Default Re: what radiator on an ef civic hatch? (Jdmsolutions)
help ef people!!
Old May 8, 2007 | 10:16 AM
Bakeoff's Avatar
Doing the EG radiator in an EF, you'll ahve to make up some brackets. It should be pretty simple, without cutting or bending up the radiator support.
Old May 8, 2007 | 08:36 PM
Default Re: (Bakeoff)
i have an eg... doesnt fit for **** unless you let it hang way back... kinda looks dumb like that
Old May 9, 2007 | 07:01 AM
IT GUY's Avatar
Default Re: (Jdmsolutions)
did you ask the question in the EF section?
Old May 10, 2007 | 11:34 AM
turboteener's Avatar
Banned
I am running an EK SI radiator, but I built a custom front crossmember and hung the radiator down in front of it so it fits in the stock location.
Old May 10, 2007 | 11:42 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmsolutions &raquo;</TD></TR><TR><TD CLASS="quote">i have an eg... doesnt fit for **** unless you let it hang way back... kinda looks dumb like that</TD></TR></TABLE>
You have to cut the radiator support, its ment to fit into an eg, not an ef. Therefore you need to cut, if done right it looks stock.
Old May 11, 2007 | 01:10 PM
Default Re: (RCautoworks)
i did ... how are you expecting the hood to close? atleast my hood wouldnt clear... im just goign to fab up a tracton bar setup and hang the son of a bitch down low
Old May 11, 2007 | 03:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmsolutions &raquo;</TD></TR><TR><TD CLASS="quote">i did ... how are you expecting the hood to close? atleast my hood wouldnt clear... im just goign to fab up a tracton bar setup and hang the son of a bitch down low</TD></TR></TABLE>
Hood closes well, he does have a carbon fiber hood but if you look at the hoods, thats where they actually bend over. Its not that hard really
Old May 11, 2007 | 03:48 PM
ManBearPig4silly's Avatar
Get a grinder and cut some **** until it fits. It's been done about 34543 million times. It's actually quite easy.
Old May 11, 2007 | 03:52 PM
Default Re: (ManBearPig4silly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ManBearPig4silly &raquo;</TD></TR><TR><TD CLASS="quote">Get a grinder and cut some **** until it fits. It's been done about 34543 million times. It's actually quite easy. </TD></TR></TABLE>
You lie pig bear arm
Old May 11, 2007 | 03:56 PM
yeah it doesn require a plasma cutter and a tig welder.
well if you are badass and awesome.
Old May 11, 2007 | 04:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ManBearPig4silly &raquo;</TD></TR><TR><TD CLASS="quote">yeah it doesn require a plasma cutter and a tig welder.
well if you are badass and awesome. </TD></TR></TABLE>
I actually used a sickle
Old May 11, 2007 | 04:04 PM
I just look at it and it fits.
Like magic only I don't need magic as I am that awesome.
Old May 11, 2007 | 04:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ManBearPig4silly &raquo;</TD></TR><TR><TD CLASS="quote">I just look at it and it fits.
Like magic only I don't need magic as I am that awesome. </TD></TR></TABLE>
The powers with in, remember to never talk to you in person though, you could think evil things and change me into a toad.
Old May 12, 2007 | 01:30 PM
hmm... wish i had a plasma.. might take a while with my **** grinder and my 10gallon air tank lol...
Old May 12, 2007 | 01:35 PM
An air grinder with a cut off should take care of it, or go buy an angle grinder from harbor freight for $10
Old May 12, 2007 | 01:40 PM
how good do your eg rads and fans do?
Old May 12, 2007 | 01:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmsolutions &raquo;</TD></TR><TR><TD CLASS="quote">how good do your eg rads and fans do? </TD></TR></TABLE>
Good as in cooling ? We run them on turbo setups and never have issues.
Old May 12, 2007 | 01:47 PM
hmm... well i think im going to go expletive up my crossmember.... probably jsut take it out and cut the expletive out of it... ill get back to you about ordering a rad and fan.. i gota wait to get paid.. thanks for your help
Old May 12, 2007 | 01:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmsolutions &raquo;</TD></TR><TR><TD CLASS="quote">hmm... well i think im going to go expletive up my crossmember.... probably jsut take it out and cut the expletive out of it... ill get back to you about ordering a rad and fan.. i gota wait to get paid.. thanks for your help </TD></TR></TABLE>
I thought you already had the radiator ? If you do it right, the crossmember does not have to be cut at all.
Old May 12, 2007 | 02:04 PM
what do you mean? what would i change then? and yes i have the rad but its used... i would rather get a new one..
Old May 12, 2007 | 02:08 PM
You cut the radiator support, then drop it down. The only time the crossmember was cut when I did it, was if the drain plug is in the way
Old May 12, 2007 | 02:12 PM
hmm.... that seems easier i guess... how much do i need to cut out? jsut like 1/2inch?
Old May 12, 2007 | 05:14 PM
About that, maybe an inch or 2
HatchMo
Aug 1, 2006 08:31 PM
Magic Wheels
Jul 10, 2004 09:07 PM
^Sammy]!.
Dec 19, 2003 07:54 PM
Cereal_Killer
Jan 19, 2002 01:00 PM
