counterweight, oil pssge..
Old May 7, 2007 | 08:45 PM
soon2bdropped's Avatar
Default counterweight, oil pssge..
okay what is the purpose of a crank counterweight give me a scenario of how its used in a 4 cylinder.. i always thought when the crank spins.. the weight of the crank doesn't force the piston down when its trying to move up thats why they added the weight to it i don't really know for sure..
okay how does the oil work in the f22b1 also give a scenario start from the oil pick up/screen.. so as the pump turns on it forces oil fromt he crankcase into the pickup..and how does it work from there into the oilfilter and lube all the valves up.. explain thanks..
Old May 7, 2007 | 09:21 PM
Default Re: counterweight, oil pssge.. (soon2bdropped)
also when you overbore a cylinder the walls/sleeve gets thinner right.. so would it be better to get bigger pistons and stock size rings or stock pistons and oversized rings?
can u also use larger pistons and larger rings or no?
whats open deck.. and how do u calculate compression ratio?
Old May 9, 2007 | 03:00 PM
bump
Old May 9, 2007 | 03:48 PM
Turbowa's Avatar
Wow. Ok you will never find the complete answer here. You will get to many opinions. Got to a web sight I think its called howstuffworks.com
soon2bdropped
Sep 28, 2007 09:43 AM
Hondaruss
May 20, 2007 02:44 PM
db2integra
Sep 10, 2004 07:29 PM
ScootinIntegra
Mar 24, 2004 10:21 PM
B18EG6
Jan 2, 2003 03:17 PM
