b18 at 6000
Old May 7, 2007 | 06:17 PM
hondacrx2's Avatar
Default b18 at 6000
ok i have posted this before with out any real help. But plz do help me or tell my what ever u think could be my problem no matter how dumb it is. i have a B18 in my crx and it idles fine and runs fine up until 6000. when i hit around 6000 rpms it miss fires and i have no clue what it is. i got new plugs but they didn't do much. i do have a slight leak between my exhaust manfold and down pipe. any help or comments would be great!!!
Old May 7, 2007 | 06:27 PM
EF_LSVtec's Avatar
Default Re: b18 at 6000 (hondacrx2)
your O2 sensor could be bad...any codes?
Old May 7, 2007 | 06:46 PM
Janos Lin's Avatar
Default Re: b18 at 6000 (EF_LSVtec)
Could be the cold rev limiter? If the ECU thinks ur engine isn't hot enough, it won't let ur engine rev up past a certain point to protect the engine. Does ur temp gauge show the engine is getting hot? What is the resistance of the temperature sending unit on the side of the head that goes to the ECU when the engine is at normal operating temperature?
Janos
Old May 8, 2007 | 04:36 AM
hondacrx2's Avatar
Default Re: b18 at 6000 (Janos Lin)
Actually my tempurature gauge blew itself out during the swap so i don't know if its warm or cold. i haven't eve driven very far yet b/c it isn't inspected. So it my be to cold? Also i have never looked for codes before........ i look at the ecu to see if it flashes correct? Doi just start it then look for it to flash? thank u for ur help so far!
Old May 8, 2007 | 08:11 AM
EF_LSVtec's Avatar
Just turn the key to "on" position without starting..
Old May 8, 2007 | 10:19 AM
hondacrx2's Avatar
ok i'll look and see tonight. Also it ran fine the first time i took it out then the second time my friend mashed it all the way. Could i just reset the ecu. Or wouldn't that do anything?
Old May 8, 2007 | 04:42 PM
hondacrx2's Avatar
on a b18 what does it mean with code 8 and code 13 any help would be great!!
Old May 8, 2007 | 04:53 PM
danb18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrx2 &raquo;</TD></TR><TR><TD CLASS="quote">on a b18 what does it mean with code 8 and code 13 any help would be great!! </TD></TR></TABLE>
8 TDC - top dead centre sensor
13 BARO - atmospheric pressure sensor
Old May 9, 2007 | 08:37 AM
hondacrx2's Avatar
Default Re: b18 at 6000 (danb18c)
what is a top dead sensor do and where is it how do i fix it? i ope this doesn't make me sound to dumb!!!
Old May 9, 2007 | 08:41 AM
springthemadcap's Avatar
next to the crank pulley
Old May 9, 2007 | 09:19 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: b18 at 6000 (springthemadcap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by springthemadcap &raquo;</TD></TR><TR><TD CLASS="quote">next to the crank pulley </TD></TR></TABLE>
It should be in your distributor.
Old May 9, 2007 | 09:54 AM
hondacrx2's Avatar
Default Re: b18 at 6000 (wiZCo)
I have a distributor for a b 18b at my house so what just hook that on up and that should help??? or don't they match? thanks for the help so far!!!
Old May 9, 2007 | 10:50 AM
Janos Lin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
It should be in your distributor.</TD></TR></TABLE>
Only some newer B series, I think, 98 and up had it. But as long as hes using an OBD 1 or 0 distributor, it doesn't matter wheter it's present at the crank or not.
You havent told us which OBD version you have anyway.
Janos
Old May 9, 2007 | 03:02 PM
civickiller's Avatar
tdc sensor is in your distributor. the sensor by the crank is like a crank trigger,not needed unless your car is obd2. my 96 ls motor had one,but since im obd1 i dont need it. oh im using the obd2 distributor too with no check engine light
isitafox
Honda CR-V & Element
Mar 25, 2011 01:46 PM
nyanyut
Dec 23, 2008 03:03 PM
wheelmanbg
Mar 20, 2008 03:01 PM
98tegLSR
May 14, 2007 06:59 AM
wstef
Oct 20, 2004 01:30 AM
