Leaking oil
Old May 7, 2007 | 03:43 PM
mickiemagik's Avatar
Default Leaking oil from somewhere (pics)
It appears I am missing a bolt, would this cause the oil to leak as it is? It seems to be leaking decently and I had to top her off today. Is this bolt that is missing the same size as the other one right above it? I would like to just go to a hardware store and pick one up. Thanks in advance for any help. 1.5L sohc non-vtec
Old May 7, 2007 | 03:58 PM
Boostedb20EH2's Avatar
Default Re: Leaking oil from somewhere (mickiemagik)
I can barely see what im looking at.. thats a helluva leak...
The one on the bottom side of the dizzy?
Old May 7, 2007 | 04:00 PM
Default Re: Leaking oil from somewhere (Boostedb20EH2)
Sorry it was hard to get a clear picture of it. Yes it is at the bottom of the distributor. There is a bolt holding the top on which I am hopin gis the same size.
Old May 7, 2007 | 04:02 PM
97Ej6mike's Avatar
Looks like maybe Vavle cover gasket, its a 5$ item to replace. If not, the seal around the Dizzy maybe. That can be solved with some Gasket sealent sillicone, and letting it dry overnight.
Old May 7, 2007 | 04:03 PM
Old May 7, 2007 | 04:04 PM
Default Re: (97Ej6mike)
Well I had thought it was the valve cover gasket so I replaced it and still there. The old one didn't look bad at all though. I will look in to the seal around the distributor and see if that might be it. Thanks for the suggestions
Old May 7, 2007 | 04:05 PM
hondamark35's Avatar
Default Re: Leaking oil (mickiemagik)
no, that bolt has nothing to do with the oil leak. also i would try to get the bolt off of a car in the junk yard rather than from a bolts bin. they just aren't the same.
the leak looks like it's coming from the dist. o-ring and maybe the valve cover gasket. i would replace both to be safe. remember when you replace the vc gasket put grey RTV on the corners at the cam "hump".
Old May 7, 2007 | 04:12 PM
Default Re: Leaking oil (hondamark35)
Thanks, seems like it is most likely the distributor o-ring. I don't think it is the calve cover gasket, but it is definitely something behind the distributor. Easy fix?
Old May 7, 2007 | 04:15 PM
nWilk666's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Looks like maybe Vavle cover gasket, its a 5$ item to replace. If not, the seal around the Dizzy maybe. That can be solved with some Gasket sealent sillicone, and letting it dry overnight.</TD></TR></TABLE>
more like 30
Old May 7, 2007 | 04:16 PM
Definately not anything to with that bolt. Id say valve cover gasket regardless of what everyone on here thinks.
thelizard_king
Nov 7, 2018 10:07 PM
DCAR
14
Jun 24, 2012 11:12 AM
perseverance
25
Dec 9, 2006 03:55 PM
mellowhead
Honda S2000
10
Apr 28, 2006 11:59 AM
BlueShadow
Jun 23, 2005 06:14 PM
