i replaced the egr valve and cleaned the port still throwing cel
Old May 7, 2007 | 01:22 PM
vtecaccordf22b1's Avatar
Default i replaced the egr valve and cleaned the port still throwing cel
i have a f22b1 and im throwing cel 12 witch is egr valve and i replaced it and i cleaned the port im idle at zero and it cuts off when i give it gas
Old May 7, 2007 | 01:36 PM
f23__'s Avatar
Default Re: i replaced the egr valve and cleaned the port still throwing cel (vtecaccordf22b1)
this might sound stupid but have you cleared the codes? try clearing them 1st
Old May 7, 2007 | 06:48 PM
Default Re: i replaced the egr valve and cleaned the port still throwing cel (f23__)
i cleared the code but its still running with a low idle like200 rpm and it cuts off after i give it gas
Old May 7, 2007 | 06:58 PM
hondadude's Avatar
code 12 means the EGR Lift Sensor You'll need to find out if it is getting the proper signal to the ECU.
And see if the solenoid is turning on the vacum to the EGR valve.
But saying you have a low idle makes me wonder if there might be a big vacum leak, or maybe the vacum lines are wrong and the EGR is being opened at the wrong time?
Old May 8, 2007 | 06:39 AM
Default Re: i replaced the egr valve and cleaned the port still throwing cel (hondadude)
its a 92 accord ex with a f22b1 out a 96 accord ex its been running fine till the altenator belt went bad i change the altenator belt and it started acting up i checked the altenator and it is good
Old May 8, 2007 | 12:58 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecaccordf22b1 &raquo;</TD></TR><TR><TD CLASS="quote">its a 92 accord ex with a f22b1 out a 96 accord ex its been running fine till the altenator belt went bad i change the altenator belt and it started acting up i checked the altenator and it is good</TD></TR></TABLE>
Thats all nice to hear.......Is the EGR valve staying open all the time?
Old May 8, 2007 | 03:33 PM
lowered94accord's Avatar
you may want to check to see if you plugged the sensor back up on the egr valve..i did this recently..I took the egr valve off to clean it and forgot to plug it back up therefore I threw a code 12...but no more cel for me
SONIC BOOM
Jul 10, 2006 10:54 AM
zseeanz
Dec 29, 2004 01:15 AM
Thrillhouse
Sep 5, 2004 04:40 PM
Ricey McRicerton
Mar 19, 2004 09:11 AM
