How the heck did you guys get your Profec B wiring thru the firewall?!?!?
Old May 30, 2002 | 07:22 PM
shamoo's Avatar
Will you make something up for me please?
Default How the heck did you guys get your Profec B wiring thru the firewall?!?!?
I'm having a hard as hell time trying to find a place on the firewall to get the thick vacuum line/wire clip of the Profec B thru the firewall.
I had a hard enough time getting a small power wire through for my radio, now I have to do this?
Help me out guys. Where did you put yours through? Pics?
Thanks
Old May 30, 2002 | 07:35 PM
DR. ON POINT's Avatar
Banned
Default Re: How the heck did you guys get your Profec B wiring thru the firewall?!?!? (shamoo)
drill a hole
Old May 30, 2002 | 07:44 PM
2K_TEG's Avatar
Default Re: How the heck did you guys get your Profec B wiring thru the firewall?!?!? (On Point EK!!!!!!!!)
drill a hole
make sure you use a grommet.
Old May 30, 2002 | 07:56 PM
Replica_Racer's Avatar
Default Re: How the heck did you guys get your Profec B wiring thru the firewall?!?!? (94hondahybrid)
Im not to sure if the profec a wiring harness is the same, but i fead the line threw a hole next to the battery. Its behind the ac/heater stuff under the dash.
Old May 30, 2002 | 08:14 PM
bottlefedb18c1's Avatar
watch out my freind took his car to best buy for a system and they drilled a hole in the a/c condenser and they said they didnt do it i work at an automotive instaltion shop and it is very posible to put a new hole in
Old May 30, 2002 | 09:42 PM
SIK IN DA HED's Avatar
New User
Default Re: How the heck did you guys get your Profec B wiring thru the firewall?!?!? (turboorangecx)
i also recommend this hole. alot of people also use this hole for cables for audio components. it works.
Old May 30, 2002 | 10:49 PM
shamoo's Avatar
Default Re: How the heck did you guys get your Profec B wiring thru the firewall?!?!? (dlplayboy)
Thanks guys, I'll try that tomorrow. But the wire has a fat clip on it, plus I have a soft vacuum line to feed through.
I had a hard enough time shoving a hanger through that battery area hole.
Thanks.
Dontoh
11
Jun 30, 2011 11:39 AM
mrdeadman
Audio / Security / Video
Mar 6, 2010 11:54 AM
3.3.3
Jan 11, 2004 05:13 PM
xstalkrx
Apr 10, 2003 04:54 PM
