Which tranny for supercharger?
Old May 7, 2007 | 09:17 AM
team 15's Avatar
Default Which tranny for supercharger?
I want to know which tranny is best for supercharging a d16y8? Will a dx tranny be then best caue it have longer gear ratio or ex?
Old May 7, 2007 | 09:42 AM
Syndacate's Avatar
Default Re: Which tranny for supercharger? (team 15)
Why would you want longer gearing?
It shouldn't matter, you're making more power, it doesn't mean you're going faster.
The speed limits still 55 and the fuel cut-off's still 125. This is a stupid question, if you're making it for drag racing then obviously a custom trans is in order, but if you wanna stay w/ OEM trans's you'd obviously want the shortest (which is the EX). There's NO reason to get taller gears b/c u supercharged. If anything that'd be trying to nullify the effects of the supercharger b/c ur having more power but it's taking longer to put it down. Major downgrade.
Keep the trans you have.
EDIT:
PS: Boosting a Y8 is stupid, ur better off turbocharging it, the displacement is pathetically small and superchargers are very reliant on displacement. With a 10lb pulley ur still only looking at like 160-180whp b/c of the **** displacement. Not worth it.
Old May 7, 2007 | 10:07 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Which tranny for supercharger? (Syndacate)
There's a good reason 99% of 4 bangers that are using forced induction are turboed.
Even most 6 cylinders prefer turbos.
You'll make more power with less money more efficiently with a turbo.
Old May 7, 2007 | 01:22 PM
broketuner-Sol_Si's Avatar
Default Re: Which tranny for supercharger? (ek forever guy)
as said, turboing would be much better than going with an SC(unless of course you crave absolutely instant power from idle).
and yes an EX trans would be better because of the shorter gearing (maybe put an lx/dx 5th gear for freway driving)
Old May 7, 2007 | 01:35 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">There's a good reason 99% of 4 bangers that are using forced induction are turboed.
You'll make more power with less money more efficiently with a turbo.</TD></TR></TABLE>
phew, this is fuel for a forced induction debate...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">It shouldn't matter, you're making more power, it doesn't mean you're going faster.
Keep the trans you have.</TD></TR></TABLE>
Agreed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">PS: Boosting a Y8 is stupid, ur better off turbocharging it, the displacement is pathetically small and superchargers are very reliant on displacement. With a 10lb pulley ur still only looking at like 160-180whp b/c of the **** displacement. Not worth it.</TD></TR></TABLE>
Ok, let's agree to disagree on this one. 6-7 lbs should be about the power range you specified. I disagree on the statement relating to displacement though.
Unseen Racer
11
Aug 2, 2009 10:29 PM
j0keefe21
Jul 20, 2009 06:18 PM
tobe1424
Dec 4, 2005 08:06 PM
fizeks
Apr 7, 2005 12:05 AM
Kyles ej1
Aug 19, 2004 06:05 PM
