Does a p30 ac bracket fit a jdm gsr block?
Old May 7, 2007 | 02:48 AM
BoRiCuA's Avatar
Default Does a p30 ac bracket fit a jdm gsr block?
I know they are lots of results if you search, but their is not a direct answer everything is a "IF", So can someone shed some light on this Ac stuff and maybe make it a sticky thanks
Old May 7, 2007 | 12:44 PM
BoRiCuA's Avatar
Default Re: Does a p30 ac bracket fit a jdm gsr block? (BoRiCuA)
HELP.....
Old May 7, 2007 | 12:47 PM
Downey's Avatar
im pretty sure the p72, p73, p30 and p54 brackets will all fit.
use the p30 or p54 is ur gonna keep ur civic ac compressor.
Old May 7, 2007 | 12:57 PM
BoRiCuA's Avatar
Default Re: Does a p30 ac bracket fit a jdm gsr block? (Downey)
so if i get the p30 bracket it will bolt up to the gsr block, and i can use the civic ac compressor?
Old May 7, 2007 | 02:06 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">
use the p30 or p54 is ur gonna keep ur civic ac compressor.</TD></TR></TABLE>
I think you mean p54 (del-sol VTEC) or p7j (96-00 CRV) for a civic compressor on a B-series motor. I know for a fact that p7j fits the civic compressor since I have one on my civic w/ B18c swap right now...
What car is the P30 engine bracket out of?
Old May 7, 2007 | 02:09 PM
dek1mfk's Avatar
Default Re: Does a p30 ac bracket fit a jdm gsr block? (94eg!)
i believe the p30 is from a 99-00 si, i have one for sale by the way pm me.
Old May 7, 2007 | 03:35 PM
BoRiCuA's Avatar
Default Re: Does a p30 ac bracket fit a jdm gsr block? (dek1mfk)
Well if the p30 works on my b18c block with my civic ac compressor i'll buy it, can someone please confirm or unconfirm this please!![QUOTE=94eg!]
Does the crv bracket have the torque mount also? I would like the reinforcement up front
Old May 7, 2007 | 04:58 PM
94eg!'s Avatar
#1 Super Guy
Loved
Yes. It's the same thing as the Del Sol VTEC mount with slightly different shaped weight reduction holes. Plus it cost about half. My car is an EG civic. I don't know about EKs w/ a/c...
Old May 9, 2007 | 06:12 PM
BoRiCuA's Avatar
If i use the p30 bracket which comes out of the 99-00 civic i believe b16a2, can i use the single cam ac compressor?
Old May 12, 2007 | 04:17 AM
RedZone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoRiCuA &raquo;</TD></TR><TR><TD CLASS="quote">If i use the p30 bracket which comes out of the 99-00 civic i believe b16a2, can i use the single cam ac compressor?</TD></TR></TABLE>
no P30 is for Bseries compressors only you will need a P54 or P7J if you are going to use a D series AC compressor......I would order one fromt he dealer since they are a little harder to find....
Old May 14, 2007 | 07:35 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Does a p30 ac bracket fit a jdm gsr block? (RedZone)
Comparing these two compressors it is obvious you cannot mount one on the others bracket. The bolt holes are in different locations. As RedZone stated, you will need the P54 or P7J mount bracket to make it work...
94 Civic CX:
99 Civic Si:
kenji
Nov 2, 2010 12:35 AM
marc-111
Aug 24, 2005 12:47 PM
CRVRX
Jan 27, 2005 01:03 PM
kenji
Dec 3, 2002 03:38 PM
kenji
15
Dec 3, 2002 02:28 AM
