need bigtime advice on this build up... my first import
Old May 7, 2007 | 12:08 AM
TypeRbuild718's Avatar
Default need bigtime advice on this build up... my first import
so for i have a pr3 itr head and a b18c block(i got some eagle rods and coated racing rod bearings...and ill be sure to get some nice low compression forged pistons)..and i have some new capped 450 cc turbo injectors......i assume i would have to get a pr3 intake manifold and headers to bold on the head with a right fit.....can i use n e b16 obdi electrical set up.... id really wanna build it up obdi chipped.... but what i mean is what starter ,disty , oil pump . water pump ,timing belt sytem,pulley assembly,fpr,fuel rail...etc..do i use? do i use gsr b18 distys n such... or b16 si vtec parts.... i have no car for this motor im building it up all first. im hoping to get a nice 2door acura shell to drop it in.....but not sure yet....
if someone could give me a run down list of what parts exactly imma need to build up this b16 itr and b18c obdi motor.......the more exact and precise the list the
Old May 7, 2007 | 12:44 AM
NBPdEeCeE's Avatar
* B A N N E D *
Default Re: need bigtime advice on this build up... my first import (KidBluff718)
I think you'd have better luck in the All-Motor forum, as the people in here are expecting ITR related topics. Also they dislike run on sentences, bad grammar and punctation
Good luck sir, heres a link to get you to where you wanna be :
https://honda-tech.com/zeroforum/44
215HPLSVTEC
Mar 19, 2008 09:41 AM
TypeRbuild718
May 7, 2007 03:17 AM
TypeRbuild718
May 7, 2007 12:01 AM
chadmasterc
Oct 8, 2005 06:47 AM
4g4me
Oct 30, 2002 08:52 AM
