// How can I remove this ???
Old May 6, 2007 | 09:37 PM
Grip-1EM's Avatar
Default // How can I remove this ???
So today i finally took off that stupid front plate my car had. I was wundering how would i go about removing those holes that are left on the bumper.
I live in florida so i dont need the front plate but those nostrils on the bumpers are looking ugly. Any sugestions would be great. Thanks
Old May 6, 2007 | 09:38 PM
Archidictus's Avatar
Unceasing Measure
Fiberglass patch behind with a bit of fiberglass/bondo/plastic flex filler, sanding and paint.
Old May 6, 2007 | 09:55 PM
confucioussae's Avatar
Default Re: // How can I remove this ??? (Grip-1EM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip-1EM &raquo;</TD></TR><TR><TD CLASS="quote">Any sugestions would be great. Thanks </TD></TR></TABLE>
Talk to a dealer or find some H-T members who are selling plugs
they look like this
Old May 6, 2007 | 09:56 PM
airmax's Avatar
is this a trick question.. you can't take off those holes. you can however cover it up with those oem license plate caps or bondo it and smooth it out.
Old May 6, 2007 | 09:58 PM
Default Re: (airmax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airmax &raquo;</TD></TR><TR><TD CLASS="quote">is this a trick question.. you can't take off those holes. you can however cover it up with those oem license plate caps or bondo it and smooth it out.</TD></TR></TABLE>yes you can, just do what archidictus said. cut them out and fill them smooth. whatever floats your boat if you think its worth it.
Old May 13, 2007 | 08:22 PM
Grip-1EM's Avatar
Default Re: // How can I remove this ??? (confucioussae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucioussae &raquo;</TD></TR><TR><TD CLASS="quote">
they look like this
Thanks, I do like the plug idea better
Old May 13, 2007 | 08:36 PM
cambopheonix56's Avatar
If its illegal to have no front plate in fl, I would keep it on.
Old May 13, 2007 | 08:42 PM
95ProjectEJ1's Avatar
Default Re: // How can I remove this ??? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">If its illegal to have no front plate in fl, I would keep it on.</TD></TR></TABLE>
I would just keep the plate where it is, because if you re-locate it and put those plugs in IMO its going to look like ****.
Old May 13, 2007 | 09:37 PM
SiYouLater's Avatar
Get some plugs, put the plate under your seat or in your trunk, next to a pack of license plate screws. If a cop pulls you over, tell him you were going to do it when you get home. Not sure if it works or not though.
Old May 13, 2007 | 09:46 PM
Team RS2's Avatar
Default Re: // How can I remove this ??? (SiYouLater)
couldnt find th plug so i just took a license plate bolt screwed it in, cut the head off it then fiberglassed over it apaint then primer
i also do that hwne im filling in holes that i dont need under the hood when i shaved my bay of course i cut the bolt head off then welded it then ground at it then finall fiber glassed everything primered and painted
Old May 13, 2007 | 09:49 PM
SloAZSol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater &raquo;</TD></TR><TR><TD CLASS="quote">Get some plugs, put the plate under your seat or in your trunk, next to a pack of license plate screws. If a cop pulls you over, tell him you were going to do it when you get home. Not sure if it works or not though.</TD></TR></TABLE>
great idea just dont get pulled over twice
Old May 14, 2007 | 12:32 AM
dem0nk1d's Avatar
you can fix it with a hammer
Old May 14, 2007 | 12:42 AM
Jhonny Ricer's Avatar
Default Re: (dem0nk1d)
Or you could just put the front license plate in your windshield in the bottom driverside corner they wont pull you over I've been driving like that here in NJ for the past 3 months now with no problems. They dont need it they dont read the front plate anyway unless its sitting in a parking lot.
Old May 21, 2007 | 10:36 PM
Grip-1EM's Avatar
Default Re: (Jhonny Ricer)
We only get on plate in florida and it goes on the rear. I still need to stop by honda and check out if i can get thoose plugs painted from them. Ill keep ya posted.
Old May 21, 2007 | 11:06 PM
alacard's Avatar
Default Re: (Grip-1EM)
Not sure if they come painted or not. But you can buy the plugs, and buy touch-up paint from honda.
Old May 21, 2007 | 11:21 PM
Jagolas's Avatar
Default Re: (alacard)
it'd prob be cheaper to buy them from someone on HT, i've seen them go cheap on the marketplace
Old May 21, 2007 | 11:22 PM
You can buy them here on H-T already painted in the FS forum.
I'll see if I can find the thread.
Old May 22, 2007 | 11:44 PM
Grip-1EM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">You can buy them here on H-T already painted in the FS forum.
cool thanks, Ill do some search on here to see if i can find someone selling it.
Old May 22, 2007 | 11:51 PM
Team RS2's Avatar
my daily driver accord (hard to see but its completley smooth couldnt even tell theree was a place for the plate)
Old May 23, 2007 | 04:02 AM
JSPECSIR's Avatar
Default Re: (Team RS2)
i cut mine out with a bullet grinder, put masking tape acrosss the front and filled it with duramix from the back. then while the duramix was still pliable we stuck the duramix nylon tape across the back. once it dryed we pulled the masking tape off the front and filled a couple of pinholes with body filler, sprayed it with sealer and painted it like normal. now you cant tell they were ever there.
siriussr
Northwest
Apr 22, 2008 12:14 PM
lilpimpin705
Paint and Body
Apr 19, 2008 05:45 PM
S2KILLA
Honda S2000
Mar 7, 2007 05:52 AM
kickinchicken
Jan 1, 2005 10:23 AM
Don Jefe
Mar 13, 2004 12:27 PM
