what kind of temps do you SFWD guys see?
just wondering what kind of temperatures you SFWD guys see after a full hard pass at the track.
today i was seeing about 205-210 and it seemed a bit hot to me, at one point it actually blew some fluid out the overflow bottle
temp here was about 94 degrees today.
i have an aftermarket radiator but i think it is a piece of crap
staged - 92c (197f)
after run - 107c (224.6f)
90-95f day.
royal purple purple ice, distilled water, honda thermostat, honda fan switch, fluidyne 38mm half size w/ fan, aebs t sleeves.
street driving the car for a full day it never got hotter than 220f. never ran into any problems.
hope that helps.
90-95f day.
hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 714phil »</TD></TR><TR><TD CLASS="quote">staged - 92c (197f)
90-95f day.
hope that helps.</TD></TR></TABLE>
well then i guess i am not far off from that maybe its normal and i am just a paranoid maniac then
thanks for the info
90-95f day.
thanks for the info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProPerformance »</TD></TR><TR><TD CLASS="quote">Ran in the gump friday.It's just alittle bit cooler than L.A(lower alabama) but I hit 173 after the run</TD></TR></TABLE>
If you hit 173 after a run, then you're starting out way too cold.
To the op, i see about the same temps you're seeing or hotter, pretty much exactly what 714phil is seeing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">HP makes heat, all things being equal, an 800hp motor will make a hell of a lot more heat than a 400hp motor. </TD></TR></TABLE>
man, i have a heating problem then because im a temps right with you guys, and im no where near 400hp
lookin at my 06 NHRA LV logs....with my AITs starting at 160 BEFORE burnout...
coolant 233f staged, 239f at the end of run
AIT 166f staged, 185 end of run
yea, vegas was a little on the hot side...lol
lookin at tyler_h's logs for 06 NHRA Pomona AIT's in the 125's before burnout....
coolant 212f burnout, 224f end of run
AIT 127burnout, 149f end of run
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Haha, yeah, vegas had 120 deg ambient temp, so those are likely to be a bit on the high side.
What air temp sensors are you guys using, and where are they mounted?</TD></TR></TABLE>
im using a stock in the back of my manifold, but with the **baller A$$ C/F AIR manifold(hahah), i dont see very high IATs, maybe 105-110 after a run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpha »</TD></TR><TR><TD CLASS="quote">Stop being a baby Mike
Those temps are fine. How often are you blowing coolant out the overflow though?</TD></TR></TABLE>
its only done it twice, once up here before we went to Trackday and then this last time i ran it. ireally think its this cheap *** radiator and mismatched cap as far as the overflow goes john
Those temps are fine. How often are you blowing coolant out the overflow though?</TD></TR></TABLE>its only done it twice, once up here before we went to Trackday and then this last time i ran it. ireally think its this cheap *** radiator and mismatched cap as far as the overflow goes john
i hope LV wont be as bad this year, either way we shall be more prepared!
i was runnin stock in "stock" location on the jg edelbrock mani
tyler runs aem ait (gm sensor) on the bottom/side of the ips manifold
Modified by wHOAlly at 11:50 AM 5/9/2007
we use gm air temp switch , just in front of throttle body , course im running a tec 3 so im a outcast from the norm...water temps to 230 ,max, let you know on air temps , just added pcs..
paigepayton35
14
Sep 18, 2014 11:51 PM
