Engine not getting spark.....Ideas???
Old May 6, 2007 | 05:44 PM
Ron Burgandy's Avatar
Default Engine not getting spark.....Ideas???
I am on my third motor swap....(due to two bad transactions) Anyway, I just swapped in a sohc d16y7 into my ek and hooked everything up....and it doesn't start.
Here is what I know so far:
-Fuel pump is priming
-spark plugs, wires cap and rotor are all new and good (and in the right sequence on dizzy
-battery is brand new and not the issue.
-when I pulled a spark plug wire and turned the car over, there was no spark or arc at all on any of the cylinders.
***IMPORTANT*** since the last motors dizzy was not compatible I had to hack the plug...in the process one of the wires deep inside the thing pulled out, I found it and soldered it, but not real sure if this effected the dizzy???
SO- I guess what I am looking for with this thread are some ideas or opinions, I am trying to get ahold of another dizzy off a working 96+ to test it, but I don't want to overlook something.
Any ideas, thoughts or advice would be comforting.
Thanks
Modified by Ron Burgandy at 12:01 AM 5/7/2007
Old May 6, 2007 | 05:56 PM
Eran's Avatar
HT White Ops
My only advice is to test with another Dizzy.
Old May 6, 2007 | 11:02 PM
anyone else....?
Old May 7, 2007 | 11:46 AM
ttt
Old May 7, 2007 | 11:51 AM
bmoua's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">My only advice is to test with another Dizzy.</TD></TR></TABLE>
i agree, swap in the dizzy and see what happens.
Old May 7, 2007 | 01:49 PM
kk,
I'm expecting the thing to start right up with a new dizzy, I'll post when I have a result.
thanks
Old May 7, 2007 | 01:55 PM
93egsir's Avatar
check all the grounds the t-stat the tranny to frame rail and valve cover to bulkhead.
if not then swap dizzy if available. could be just ignitor or coil
Old May 7, 2007 | 11:19 PM
Problem solved! Thanks for your input guys, after first swapping my coil, the dizzy didn't work, I then put a brand new dizzy on and the car started right up perfectly.
I now realize how fragile some of those internal parts are in the distributor. So the lesson I learned- don't pull very hard on the wires, because you cannot solder them back together.
leon1990
Jul 7, 2012 01:00 PM
jdmshawn95
Feb 7, 2011 12:15 PM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
MikeTV
Feb 14, 2004 10:17 PM
