Tires, Balence, Alignment and still a problem. Check it out
Hey guys whats up,
So I bought me some tires and had em Mounted on
my 16"s.... Well then I had an alignment done.
Guys at my pepboys were cool as **** and got it set to like 0
Well I still have a problem,
Between 24-40MPH the car shakes, like my door panels and stuff Very vilently.
And then at any speed when I hit the gas it vibrates,
I know its coming from the front end,
Mostly felt thru the pedals,
Which, Makes me think of course the front susp and hub asembly,
So my question is, If my Upper Controle Arm Ball Joints are bad could this
be the problem?
Let me know, Been trying to track this problem down.
Oh yeah, Pointless pic. :giggle:
be the problem?
lower ball joints r new, so are the axles but they might be bad,
their the lifetime autozone ones...
Guess I'll go get new axles, and upper ball joints,
with the car that low, are you sure your axle is not rubbing against any other suspension part? btw, do you know DA low like that kill handling? coz i can see the roll center is lower than the ground.
I'm guessing you don't have any hubcentric rings so you should try to make it lug-centric. Try this: Jack the car up and loosen the lug nuts. Then tighten them back up and torque them to 80 ft/lbs with the wheel completely off the ground.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stupidwhitecat »</TD></TR><TR><TD CLASS="quote"> Do they require hub centric rings? </TD></TR></TABLE>
No, It does the same thing with my Steelies on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_ek9 »</TD></TR><TR><TD CLASS="quote">with the car that low, are you sure your axle is not rubbing against any other suspension part? btw, do you know DA low like that kill handling? coz i can see the roll center is lower than the ground.</TD></TR></TABLE>
English please... the roll is lower than the ground...? wtf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Savannahdc2 »</TD></TR><TR><TD CLASS="quote">Motor mounts, wheel bearings, bushings, and wheel might need hub rings.</TD></TR></TABLE>
Mounts are all new With ES inserts, its not that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Have you retorqued the lug nuts? Are the lugs correct for the wheels (tapered vs. acorn)?</TD></TR></TABLE>
I can double check to make sure their trqed right....
Shop trqed em when they did the alignment... no difference before and after
I'll check, their Tuner Lug nuts
Not sure the name, a friend said their hard to get or soemthing. idk...
I bought em this weekend
But Stock lug nuts and now these tuners, Made no difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::MYCORD:: »</TD></TR><TR><TD CLASS="quote">I'm guessing you don't have any hubcentric rings so you should try to make it lug-centric. Try this: Jack the car up and loosen the lug nuts. Then tighten them back up and torque them to 80 ft/lbs with the wheel completely off the ground. </TD></TR></TABLE>
K I guess I'll try that tomm.... But wheels didnt make a difference,
This all happened when I had steelies....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jose-aka-Pedro »</TD></TR><TR><TD CLASS="quote">
it is indeed english, read again, the roll center is lower than the ground.
if you still have doubt, read this, http://en.wikipedia.org/wiki/Roll_center
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jose-aka-Pedro »</TD></TR><TR><TD CLASS="quote">Between 24-40MPH the car shakes, like my door panels and stuff Very vilently.
Axles... ball joints and wheel bearing would knock on bumps rather than cause vibration.
Key point is the accelerating causing the vibration which points to the axles or CV joints. Check for loose joints, when you're under the car grab the shaft and push up and down and check for play. Side to side movement is normal.
violent shaking/vibrations while on the gas = bad inner CV joints.
I put on crap axles from AutoZone/NAPA (same brand) and ended up having to pull them off and replace them 3 times because I kept getting bad axles.
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">violent shaking/vibrations while on the gas = bad inner CV joints.
I put on crap axles from AutoZone/NAPA (same brand) and ended up having to pull them off and replace them 3 times because I kept getting bad axles.</TD></TR></TABLE>
agreed.
if you still have doubt, read this, http://en.wikipedia.org/wiki/Roll_center</TD></TR></TABLE>
look, dude...I dont know if you're trying to sound smart or what....but check this out. Everyone knows that the lower a car is, the better it will handle. The more tire you tuck, the better you can turn...duh. To make the car roll less, just get 14k springs front and rear. Maybe even 18k.
jk. You're right.
agreed.
jk. You're right.
I saw a link that had a nice diagram of what roll center is and why it's bad to lower a car too much. I dunno where it is, tho. You can probably find it in the suspension forum somewheres.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
jk. You're right.</TD></TR></TABLE>
haha, dude, the super low style is mad tight yo
well, always see many DA driving like that low on freeway, the car is not stable every time i saw them hitting a bump over 80mph. DA can handle great, but not at that height.
