How-To Drop motor from DA
Old May 6, 2007 | 11:38 AM
bodiby's Avatar
Default How Do I Drop The Motor from DA
I did a search. (there should be a smilie for this!)
I have a DA with Auto. I want to drop the engine out of the bottom onto a creeper. What are the steps? I know I need to pull the hubs. I have jack stands, a floor jack, a compressor, and an impact wrench. I am just going to start pulling things off for now.
Modified by bodiby at 9:07 PM 5/6/2007
Old May 6, 2007 | 08:18 PM
bodiby's Avatar
Default Re: How Do I Drop The Motor from DA (bodiby)
I pulled all the cooling, about half the A/C. I busted the axle nuts and started bulling the brakes off.
Old May 6, 2007 | 08:44 PM
Jtuned DC2's Avatar
* B A N N E D *
just put the creeper under the motor disconnect everything, then when all the mounts are off and axles tooken off. raise the car and slide the creeper out of there (with the engine on the creeper of course) and lower the car back down. u better have a high lifting jack.
Old May 6, 2007 | 08:48 PM
bodiby's Avatar
Default Re: (KevLo)
I don't think my jack will lift it high enough, so I am going to clear a path with the sawz-all. I can remove the front sub-frame and cut out the radiator support. The radiator support is bent so I am not really destroying anything useful.
Ericjergs
Paint and Body
May 29, 2018 11:14 PM
1998_4dr_gsr
Sep 22, 2008 06:32 AM
LukieLuc
Apr 12, 2007 11:49 AM
TurboTeG4
Oct 26, 2004 06:48 PM
lsvtec101
Nov 19, 2003 08:13 AM
