b16 crank in a b18 block
Old May 6, 2007 | 11:12 AM
hondacivic0909's Avatar
Default b16 crank in a b18 block
i gonna buy a b18 block and i was wondering if a b16 crank will work for it and if i would need different rods and what not (help Help)
Old May 6, 2007 | 11:26 AM
iluvmyef9's Avatar
Default Re: b16 crank in a b18 block (hondacivic0909)
what why in the hell would you want to do that the b18 is a long block and the b16 is a short block the stroke on the crank is compleaty different i mean if you couold pull it off and have the crank turn i would like to see how its done but i would never do it do a ls/vtec or if you like the b16 crank just buy a b16 block i have one for sale
Old May 6, 2007 | 11:33 AM
Default Re: b16 crank in a b18 block (iluvmyef9)
thanks how much u want for the block
Old May 6, 2007 | 11:39 AM
jdmboyef9's Avatar
I have a B20 crank that you can use stock ls/b20 connecting rods on to keep it a 1.8L. Very good condition too with low miles just collecting dust in my room...cheap!!
Old May 6, 2007 | 11:41 AM
iluvmyef9's Avatar
Default Re: (jdmboyef9)
make me an offer
Old May 6, 2007 | 11:42 AM
the b20 crank will work with a b18 block an head? and how much u want for the crank
Old May 6, 2007 | 11:43 AM
swifty4u's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmyef9 &raquo;</TD></TR><TR><TD CLASS="quote">what why in the hell would you want to do that the b18 is a long block and the b16 is a short block t</TD></TR></TABLE>
what!?
your an idiot
a long block means a block and head together
a short block means just the block
it has nothing to do with the size of the motor
Old May 6, 2007 | 11:54 AM
Default Re: (iluvmyef9)
how bout 100 bucks
Old May 6, 2007 | 12:08 PM
abnaasefmb's Avatar
Default Re: (hondacivic0909)
Old May 6, 2007 | 12:12 PM
jdmboyef9's Avatar
The B20 crank is basically the same as an LS. The blocks are too. Only real diff. is the B20 has 84mm pistons and the LS is 81mm. The rods are even the same PR4. The one that I have I'll sell it for $50 plus shipping. I pulled it out of my JDM B20 to replace with a Type R crank but thats a different story.
Old May 6, 2007 | 12:20 PM
well where u from and i cant post nomore so email me at hondacivic0909@yahoo.com but what ur sayin is that the b20 crank willwork with b18 rods cause im gonna get my b18 sleeved to 84.5mm bore do u know if the stroke would be any different between the b18 cranks and the b20 cranks
Old May 6, 2007 | 01:45 PM
jdmboyef9's Avatar
I'm in Portland Oregon. The crank for the B20 is the same as the 1.8L LS, however, The GSR B18C crank has a smaller stroke. You get more tourqe with the LS/B20 crank.
Old May 6, 2007 | 01:49 PM
jdmboyef9's Avatar
I believe that I still have the original B20 pistons and rods aswell. You need to use the right rods for the crank(gsr/type-r rods won't work with LS crank).
jspec - integra Ls
Jun 12, 2021 03:54 PM
vtec8200
11
Jun 13, 2011 10:04 AM
TylerB
Apr 22, 2004 07:23 PM
shotty
Aug 12, 2002 05:04 PM
TedR719
Jul 28, 2002 02:05 AM
