compression on motor only 130 all across? runs fine?
Old May 6, 2007 | 10:59 AM
97grnrs's Avatar
Default compression on motor only 130 all across? runs fine?
i just put a d15b2 block in my crx. i used the d16a6 head.. motor is turboed.. i just did a compression test and every cyl went only to 130 then stopped.. either my gauge is broken or that combo makes a low comp motor .. any ideas? it runs fine and dont smoke either.
Old May 6, 2007 | 11:11 AM
abnaasefmb's Avatar
Default Re: compression on motor only 130 all across? runs fine? (97grnrs)
I’ve seen a lot of fluctuation for different gauges, also was the engine warmed up and did you do the test with the throttle open?
Old May 6, 2007 | 11:15 AM
SIred91's Avatar
Rainman
With that combo you are just fine. You need consistency, not high numbers.
Do a dry and wet compression check. After dry testing, put a teaspoon of oil down the hole and run the check again. Doing each cylinder by itself and seperate, dry then wet.
If everything is good, the numbers will be the same across the board but about 10 or so psi higher than dry.
slammedbbs
May 9, 2011 04:14 AM
sirguy01
Jul 6, 2006 09:03 PM
mugenhatchie
Apr 3, 2006 12:31 AM
SPOON_FED_DC_2
Apr 6, 2005 09:19 PM
