EG / DC suspension components the same ?
Old May 5, 2007 | 10:38 PM
allmotorpackage's Avatar
Default EG / DC suspension components the same ?
yo , i jus picked up an ej2 94 civic coupe DX . It is only a shell that is missing alot of misc parts such as Front and Rear Control arms , Tie rod ends , and the Header all the way to the muffler.
I have alot of misc parts laying around the garage from my old 94 integra gsr and i was wondering if i can use the Front and Rear Lower Control arms , the front upper control arms , tie rod ends , and the catback exhaust to piece together for my new civic coupe project ?
Simply put , are the following parts the same between the 92-95 civic coupe dx and the 94-97 integra gsr
- front lower control arms
- front upper control arms
- outer tie rod ends
- rear lower control arms
- catback exhaust
Old May 5, 2007 | 10:42 PM
chrisw85's Avatar
Everything but the exhaust will fit without modification. Suspension arms are interchangeable between the 92-95 and 94-01 Integras, with the exception of the 'R' which have different rear lower arms.
Old May 6, 2007 | 01:26 AM
BlueIntegraBoy's Avatar
Default Re: (chrisw85)
You can still swap over ITR rear LCAs, but you will need the eye-type ITR struts.
Old May 6, 2007 | 07:25 AM
suspendedHatch's Avatar
Default Re: EG / DC suspension components the same ? (allmotorpackage)
yo, mtv raps!
Old May 8, 2007 | 09:55 AM
Default Re: EG / DC suspension components the same ? (suspendedHatch)
will there be any negative effects if i use the integra tie rod onto the civic and go to alignment rack or are they completely the same part ?
KdiZzLe
Jul 23, 2013 09:35 PM
passwordjdm
Oct 9, 2012 10:31 AM
95cx
Apr 24, 2009 06:14 AM
Novtec4u
Oct 23, 2008 04:48 PM
deftones0817
Sep 1, 2002 11:47 AM
