gsr lower control arms
are the 94+ gsr lower control arms the same as the 92-95 civics?
If they are...are the bushings the same as well? If not will they bolt up to a 92-95 civic coupe?
The reason I was asking is because my suspension sucks and I bough a poly kit from energy suspension and then i thought later hey maybe i should get gsr control arms sense im going to put gsr brakes all the way around on the civic...so are the arms the same? mine are messed up so I need new ones anyways...so if they are the same will the bushing kit i got work or no and will i need anything else besides control arms? Thanks in advance
Josh
Josh
Re: gsr lower control arms (drvfast)
so the front lower control arms are the same as the civic control arms? And I wont need new bushing kit when I buy the front gsr front lower control arms? Please verify thank you.
Josh
Josh
Re: gsr lower control arms (speshuled619)
is it possible to just drill a drill in the LCA instead of buying gsr LCA's?
1320fuel.com
01-21-2014 03:04 PM
