B20 with gsr head
Old May 5, 2007 | 10:26 PM
EKlp's Avatar
Default B20 with gsr head CAN SOME1 Help me!!!
i need to get the motor mount for the driver side the top one also need to find a vtec control and a chipped ls ecu unless i can put something else im dumping the engine in a civic hatch 97
Modified by JlpM at 11:56 PM 5/5/2007
Old May 5, 2007 | 10:31 PM
dannis.'s Avatar
Default Re: B20 with gsr head (JlpM)
okay i couldn't make sense of anything you wrote. i dont understand if your trying to ask a question or buy something... please rewrite this.
Old May 5, 2007 | 10:35 PM
EKlp's Avatar
Default Re: B20 with gsr head (dannis.)
hahah thats what i get for putting my lil bro to type!!! i need help finding the driver top side motor mount that would fit on my car i have a b20 with the gsr head inside of an EK and also what kind of ecu should i get> people tell me to get the ls chipped and other to get the GSR
Old May 5, 2007 | 11:06 PM
EKlp's Avatar
Default Re: B20 with gsr head (JJSpecTuning)
yea it is getting converted but they told me that i wont be able to run vtec or something like that beacuse of the knock out sensor is dat true? unless i get a boost control
Old May 5, 2007 | 11:36 PM
dannis.'s Avatar
Default Re: B20 with gsr head (EKlp)
yeah just find a knock sensor off any B series motor. cause your b20 should have a place for it. or you can just jump your car obd1 and run a chipped p28.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKlp &raquo;</TD></TR><TR><TD CLASS="quote">unless i get a boost control </TD></TR></TABLE>
Why do you need a boost control... yout not turbo are you.
Old May 5, 2007 | 11:58 PM
preludedriva's Avatar
its not knock out sensor its knock sensor
p28s bypass this i believe
Old May 6, 2007 | 11:27 AM
doood's Avatar
been there done that
Default Re: (preludedriva)
most engine management systems can disable the need for a knock sensor
Old May 6, 2007 | 12:55 PM
EKlp's Avatar
Default Re: (doood)
does any body have any motor mounts that could sell me that would fit on my car and throttle cable
Old May 6, 2007 | 01:23 PM
RC_Rikimaru's Avatar
Default Re: (EKlp)
yeah run the p 28 and get it chipped. It's the only ecu that does not read knock sensor.
Old May 6, 2007 | 02:51 PM
smileycvc's Avatar
Default Re: (RC_Rikimaru)
with crome or hondata you can bypass the knock sensor, and a bunch of other things if you want. To find the mounts try the marketplace.
carlossolorzano
Nov 22, 2010 07:29 AM
B20Panda
Feb 2, 2010 04:29 AM
chris23pp
Sep 9, 2007 08:15 AM
tabbob7681
Mar 12, 2006 08:05 PM
fcuk-vtec
Dec 3, 2003 04:12 PM
