93 hatch b20 motor
93 hatch b20 motor
i got a 93 hatch which had a 2000 gsr with obd1 ecu. hydrolocked the motor and now have stock b20 with gsr tranny. trying to find out what type ecu i can use on the b20 with the wiring harness from the gsr bcause i need to go thru inspection and get the vtech code off.. and also what type of cheap exhaust does anyone recomend i need to get this thing thru inspection asap
Guest
Posts: n/a
Re: 93 hatch b20 motor (smileycvc)
ive got a b20 hatch and the ls ecu is hands down the best out there for a oem ecu. theres been a few articles on b20 chips, but the general idea is that unless its going to be dyno'd b20 chips dont really work all too well
Re: 93 hatch b20 motor (vestalfootball72)
if i put the head on there i dont know how reliable and id have to waste time gettin it sleeved and gettin the head worked on. i just need a reliable car for now till i get more money to rework everything..
Re: 93 hatch b20 motor (chris23pp)
If you are keeping the block stock and just swapping on a vtec head you dont have to sleeve the motor. Just check out this thread its for an LS/Vtec but with a B20 it the same idea. https://honda-tech.com/zerothread/1676914
