Will a V-AFC be sufficient to tune an LS/VTEC?
Old May 5, 2007 | 09:04 PM
votoms888's Avatar
Default Will a V-AFC be sufficient to tune an LS/VTEC?
I have decided to build an LS/VTEC. I have done alot of research on the topic and understand that no existing ECU runs this setup well. Can I use a V-AFC to finetune this motor? Or should I get a chipped ECU and get someone t tune it? I am trying to do this swap properly on a budget.
Old May 5, 2007 | 09:39 PM
-Championship-'s Avatar
76.169.175.137
Default Re: Will a V-AFC be sufficient to tune an LS/VTEC? (votoms888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by votoms888 &raquo;</TD></TR><TR><TD CLASS="quote"> Or should I get a chipped ECU and get someone t tune it? .</TD></TR></TABLE>
you answered yourself
Old May 5, 2007 | 10:32 PM
votoms888's Avatar
Thanks. That is what I thought. Just wanted an experts opinion.
Old May 6, 2007 | 06:45 AM
Padawan's Avatar
Darth ModerVader
What year is your car and ECU? Most times, putting together a chipped ECU setup for use with Uberdata or Crome is actually less expensive than purchasing a V-AFC. Both would need to be professionally tuned for optimal results (assuming you don't have a wide-band O2, access to a dyno, or personal tuning experience), so the chipped ECU would not really be a more expensive option. while the results would be far superior.
94hondacivicvtec
11
Feb 26, 2007 03:44 PM
DGAF
Jul 14, 2005 06:07 AM
moekhanafer
May 13, 2005 07:48 PM
frostt3ch
Mar 5, 2004 03:17 AM
specie
Oct 13, 2003 07:25 AM
