what sensor is this?
Old May 5, 2007 | 05:47 PM
the.hamburglar's Avatar
Default what sensor is this?
what sensor is this called? im thinking maybe i have two plugs reversed which is why my car is running like ***. thanks
Default Re: what sensor is this? (the.hamburglar)
btw, that plug will also fit the iacv and iat. thanks
Old May 5, 2007 | 07:03 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
what engine?
Old May 5, 2007 | 07:08 PM
Danronian's Avatar
I'm thinking air purge valve? Not sure though.
Switch the plugs, reset ecu, and turn the car on again. You probably have them switched.
Default Re: what sensor is this? (oneludesol)
obd1 ls vtec
Old May 5, 2007 | 07:39 PM
Lamafia ck's Avatar
apv,i heard you only need it wen you use a obd2 ecu not really sure about it i dont use it and i got no cel
Old May 5, 2007 | 07:46 PM
Danronian's Avatar
Default Re: (Danronian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking air purge valve? Not sure though.
Old May 5, 2007 | 08:19 PM
i dont think i need that sensor. nothing seems to happen when i unplug it...
Old May 5, 2007 | 09:48 PM
onesikdb8's Avatar
It is an EVAP purge control solenoid valve. You do need it for emissions if it is strict where you are at.
Old May 5, 2007 | 09:53 PM
Default Re: (onesikdb8)
no emissions where i am...why dont i get a code when i unplug it?
Old May 6, 2007 | 05:40 AM
Luserkid's Avatar
<FONT SIZE="3">DO NOT...... I REPEAT..... DO NOT SWITCH THE IAC AND EVAP PLUGS LIKE THERE THE SAME</FONT>
EVAP and IAC run off 2 different type of power systems (ones ground and ones power) and when you switch them you could fry out the ecu. IAC is a blue/yel with a yel/blk (i believe yel/blk) and evap is a pink with another color. But yea dont mix them like whatever because your ecu will smoke cause its burning.
What exactly is your car doing thats making it run like ***?
EDIT: Im talking IAT not IAC it was to early when i wrote this.
Modified by Luserkid at 10:04 PM 5/6/2007
Old May 6, 2007 | 07:30 AM
Default Re: (JJSpecTuning)
at the moment its just looped. i dont know what to connect it to. im having idle surging issues so i thuoght i might have switched some connections giving the iacv the wrong voltage, ie reversing the two, which might explain the idling.
Old May 6, 2007 | 10:12 AM
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
What exactly is your car doing thats making it run like ***?</TD></TR></TABLE>
ya ok thanks. i didnt switch them but im thinking i have the evap and iat wires reversed. i have switched them not but im getting the same code. the code goes away when i put the iat plug (red/yel and grn/wht) to the evap....this makes no sense at all. i have searched and the (red/yel and grn/wht) is definatly the iat sensor but i get a code when its plugged into the actual sensor but the code goes away when i have it plugged into the evap.
Old May 6, 2007 | 10:35 AM
Default Re: (the.hamburglar)
ok right now i have a blk/yel and solid red wire going to that evap canister. the iat plug is now connected to the right sensor but im getting a code. it must be my iat sensor that has gone bad. im going to try a friends sensor this afternoon.
gnxpro24
45
Apr 22, 2011 07:12 AM
godlikehatch
Jan 19, 2011 07:53 PM
andyt
Feb 20, 2007 06:08 PM
1.8
Dec 29, 2004 08:51 PM
mini-cRx
Apr 15, 2004 09:37 PM
