So wtf, are my brand new axles bad??
Old May 5, 2007 | 02:08 PM
c1v1c98's Avatar
Default So wtf, are my brand new axles bad??
A couple weeks ago I put in brand new Drive Shaft Shop axles. I figured I'd do it the right way with DSS axles. The bastards cost me $290. Ever since then, I get a vibration when I accelerate. I just got an alignment, hoping that just maaybe that would fix it. But it didn't. I had no problems like that with my old leaky axles. Could my brand new, quality axles be bad? If not, what else could it be?
Old May 5, 2007 | 02:30 PM
Luserkid's Avatar
Default Re: So wtf, are my brand new axles bad?? (c1v1c98)
Did the alignment shop say anything was out of place or anything like that? Might want to call DSS and see what they say, more then likely youll be able to send it in and theyll give you an another set. What stage did you get?
Old May 5, 2007 | 02:36 PM
Mr.EM1_EK's Avatar
Default Re: So wtf, are my brand new axles bad?? (Luserkid)
thats what it sounds like
Old May 5, 2007 | 03:17 PM
c1v1c98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Did the alignment shop say anything was out of place or anything like that? Might want to call DSS and see what they say, more then likely youll be able to send it in and theyll give you an another set. What stage did you get? </TD></TR></TABLE>
I just got the OEM replacement axles. I bought them through a dealer here on HT.
Old May 5, 2007 | 03:23 PM
c1v1c98's Avatar
Also, the alignment shop said nothing about anything being out of place.
Old May 5, 2007 | 05:38 PM
Luserkid's Avatar
Try getting your wheels rebalanced.
Old May 5, 2007 | 07:29 PM
Danronian's Avatar
Make sure your wheels are balanced, and then I would blame the axles. Bad inner axle joints generally cause that problem from my personal experience.
Old May 5, 2007 | 09:51 PM
PinoyxEJ6's Avatar
My best guess is that, you installed the axels incorrectly & you should quickly review it agian before it becomes extremly damaged.
Old May 6, 2007 | 06:01 AM
c1v1c98's Avatar
Default Re: So wtf, are my brand new axles bad?? (Yikez itz Jayr)
I have brand new wheels and tires that were mounted and balanced 3 weeks ago. They were fine before I put these new axles in. So it shouldn't be that.
I don't know how I could have installed them wrong. I installed axles one other time and that was when I swapped out my D16Y8 for a B18C. Thats was back in July. Never had any problems.
I pushed the new axles as far as they could go into the trans and onto the intermediate shaft. And as far as they could go into the hubs.
I'll pull off my wheels and get under my car to check them out tomorrow.
Old May 6, 2007 | 06:39 AM
Damon Reeves's Avatar
does it click? especially when you are turning the wheel?
Old May 6, 2007 | 07:43 AM
c1v1c98's Avatar
Default Re: So wtf, are my brand new axles bad?? (Damon Reeves)
It does NOT click.
Old May 6, 2007 | 08:03 AM
zerovandez's Avatar
This same thing is happening to me. Knocking/ticking with vibration while accelerating. Someone help us!
Old May 6, 2007 | 08:19 AM
deadline's Avatar
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">This same thing is happening to me. Knocking/ticking with vibration while accelerating. Someone help us!</TD></TR></TABLE>
mines click but i dont have a ripped boot or anything..help us x2
Old May 6, 2007 | 08:59 AM
93 ls's Avatar
I had the same problem. Just replace them with oem and your troubles are gone.
Old May 6, 2007 | 09:09 AM
PinoyxEJ6's Avatar
Default Re: (93 ls)
hemm, yeah my best guess is just to use the OEM.
Old May 6, 2007 | 09:43 AM
95DxSi-R2
Guest
Posts: n/a
try putting your old axles back in and see if the shudder/vibration is still there. could also be a wheel bearing
Old May 15, 2007 | 07:02 PM
mastakmk's Avatar
Default Re: So wtf, are my brand new axles bad?? (95DxSi-R2)
check make sure the axle nut is secured tightly next i would replace the wheel bearing if that has not ever been replaced.. i believe its a 60k mile service part. i replaced my passenger side at 140 ish. driverside is still on over 150 on body. axles are an ez replacement. if you can get the damn nut off.. LOL. just stripped mine today! will take a bit to get it off. tried multiple ideas. from heating-to welding. bitch will not come off. well good luck with both of your problems!
Old May 15, 2007 | 08:37 PM
Ek Zero's Avatar
If he said only vibrate on acceleration, it must something deal with the drive axles.
For Mastakmk -- I think all you need is Ingersol Rand 2135Ti to get the nut off ....
Old May 16, 2007 | 08:29 AM
mastakmk's Avatar
Default Re: So wtf, are my brand new axles bad?? (Ek Zero)
yeah.. i got one not that 1 600 ft lbs but dunno it was stubborn. now. its mutilated. we'll see what happens now.
Old May 16, 2007 | 08:33 AM
mastakmk's Avatar
Default Re: So wtf, are my brand new axles bad?? (mastakmk)
with a loose axle nut. mine vibrated only on accel. just drove over to tires plus 2 secs zap zap its tight. cause i was on the road. and thats my only shop. ONLY SHOP. LOL. back to work. gotta pull the tranny bolt to motor drop motor in. PCE
Old May 16, 2007 | 10:00 AM
Civichatch2k's Avatar
Default Re: So wtf, are my brand new axles bad?? (PinoyxEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyxEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">My best guess is that, you installed the axels incorrectly & you should quickly review it agian before it becomes extremly damaged. </TD></TR></TABLE>
Dude, learn a little before you speak about stuff you dont understand. They can not be installed incorrectly as they only go in/on one way.
Old May 16, 2007 | 10:03 AM
I am having a similar problem and I am about to replace all my ball joints, both axles and my tie rod ends.
If that doesn't fix everything maybe it is on to the balance of the tires and wheel bearing.
(Just so you know, I am replacing these things out of need, not to fix the problem of vibration, although I did connect these parts with the possiblility of them fixing the vibration under acceleration.)
I will let you know...
Old May 16, 2007 | 08:44 PM
zerovandez's Avatar
guys, read my post with this problem, 94eg! (htmember) makes perfect sense. Maybe you guys can try the same!
Old May 16, 2007 | 09:25 PM
95GSRBOI's Avatar
Maybe a bad wheel bearing would be the case since all others jobs are done... or frame damage.
Vagitarian
Jul 30, 2012 09:33 AM
japinoyian09
May 6, 2009 11:45 PM
IntegR
May 7, 2006 03:41 PM
Bbasso
Jan 18, 2005 10:57 AM
-=TWITCH=-
16
Apr 6, 2002 09:22 PM
