Built For Boost B16A2 Swap FS (wiseco, eagle, skunk2, arp, oem, etc.)
I have a complete built engine for sale that has less then 4k miles on it since being rebuilt.
I never installed this engine. I purchased this from one of the top moderators of hmt.com all the work was done professionally
Im located in cocoa beach
Willing to deliver if not to far away
Block
b16a2 block
-oem honda water pump (less than 4k miles)
-oem honda oil pump (less than 4k miles)
-oem timing belt (less than 4k miles)
-oem tensioner (less than 4k miles)
-oem main and rod bearings (new)
-oem rear and main seal (new)
-wiseco 8.8:1 pistons (81mm bore) (less than 4k miles)
-eagle h beam rods (less than 4k miles)
-wiseco rings (new)
-alternator
-intermediate shaft
-tapped oil pan
-oem oil pick up (less than 4k miles)
-oem crank pulley
-arp head studs
Head
b16a2 head
-skunk 2 cam gears (less than 4k miles)
-gsr cams
-fresh valve adjustment
-vtec solenoid and all sensors
-stock intake manifold and throttle body
-stock fuel rail
-b&m fpr
-stock injectors (if you want them)
-valve cover cut for cam gears
-new oem valve cover gasket
-ngk bkr7e-11 spark plugs (less than 2k miles)
1500$obo
Block
b16a2 block
-wiseco rings (new)
-alternator
-intermediate shaft
-tapped oil pan
-oem crank pulley
-arp head studs
Head
b16a2 head
-gsr cams
-stock fuel rail
-b&m fpr
1500$obo
r1de23
Jul 15, 2009 06:30 PM
TannerCB
May 14, 2007 03:39 AM
