Built B16A2 engine central FL
Old Jan 11, 2009 | 02:34 PM
TannerCB's Avatar
Default Built B16A2 engine central FL
I have a built motor from a 2000 Si. I bought the motor from a moderator on HMT.com. Its freshly rebuilt with 4k miles on. Has a few upgrades for boost like piston, rods, head bolts, and cam gears.
block:
-b16a2 block
-oem honda water pump (less than 4k miles)
-oem honda oil pump (less than 4k miles)
-oem timing belt (less than 4k miles)
-oem tensioner (less than 4k miles)
-oem main and rod bearings (new)
-oem rear and main seal (new)
-wiseco 8.8:1 pistons (81mm bore) (less than 4k miles)
-eagle h beam rods (less than 4k miles)
-wiseco rings (new)
-alternator
-intermediate shaft
-tapped oil pan
-oem oil pick up (less than 4k miles)
-oem crank pulley
-arp head studs
head:
-b16a2 head
-skunk 2 cam gears (less than 4k miles)
-gsr cams
-fresh valve adjustment
-vtec solenoid and all sensors
-stock intake manifold and throttle body
-stock fuel rail
-b&m fpr
-stock injectors (if you want them)
-valve cover cut for cam gears
-new oem valve cover gasket
-ngk bkr7e-11 spark plugs (less than 2k miles)
Asking 1200$ accepting offers
will take pics soon located in cocoa beach florida willing to meet up
Old Jan 12, 2009 | 02:56 PM
TannerCB's Avatar
Default Re: Built B16A2 engine central FL
up
Old May 18, 2009 | 12:50 PM
ej8till's Avatar
New User
does the transmission come with it? if so is it LSD?
jdmboostedek99
Mid-Atlantic (Sales)
Apr 29, 2015 11:06 PM
r1de23
Jul 15, 2009 06:30 PM
TannerCB
Dec 14, 2007 01:58 PM
TannerCB
May 25, 2007 04:54 AM
TannerCB
May 14, 2007 03:39 AM
