I can't take a bolt off!!! header cover
Old May 4, 2007 | 10:54 PM
Rikaro's Avatar
Default I can't take a bolt off!!! header cover
there's a cover on my stock header and there's 4 bolts on it. I took the 3 off but the forth one (on the top right) is stuck. I think it's rusted. I didn't try any power tools because i'm scared of stripping it. Any tips guys?
Old May 4, 2007 | 10:55 PM
Rainy City's Avatar
Default Re: I can't take a bolt off!!! header cover (Rikaro)
PB blaster // some time of metal penetrant. Let it sit and soak as long as you can then keep trying. If the bolt breaks off, just replace the stud.
Old May 4, 2007 | 10:57 PM
Rikaro's Avatar
Default Re: I can't take a bolt off!!! header cover (Rainy City)
what if the studs get stuck in there w/o the bolt?
Old May 4, 2007 | 10:59 PM
Rikaro's Avatar
also, is it alright if i just take the sheild out and drive without it? That is if i have a stock header
thanks for answering my questions
Old May 4, 2007 | 11:32 PM
fmrprojects's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikaro &raquo;</TD></TR><TR><TD CLASS="quote">also, is it alright if i just take the sheild out and drive without it? That is if i have a stock header
thanks for answering my questions </TD></TR></TABLE>
why are you removing your header to put it back on after? if you do just use the other 3 bolts
Old May 5, 2007 | 12:28 AM
Rikaro's Avatar
Default Re: I can't take a bolt off!!! header cover (fmrprojects)
i'm removing the shield so that i can install the o2 sensor
Just1nK4ng
11
Aug 10, 2018 02:41 AM
Prudz_lude
Mar 29, 2007 01:18 PM
miataguy
May 31, 2004 09:57 AM
GSRacer93
Dec 31, 2003 09:26 AM
EF_LSVtec
Oct 3, 2002 06:30 AM
