strange start up routine
Old May 4, 2007 | 09:01 PM
iateshaggy's Avatar
Default strange start up routine
recently we noticed our 96ex will not start unless we turn the key to the on position first and wait for the gear indicator to show drive + check engine light turns on then both turn off. after they both turn off (happens at the same time) we can turn the key the rest of the way and she cranks right up.
does anyone know what this is (ecu maybe) or is this normal for accords?
Old May 4, 2007 | 09:04 PM
lowered94accord's Avatar
Default Re: strange start up routine (iateshaggy)
no thats definently not normal...you could have a bad fuel pump becuase it sounds like its taking it a while to kick on and get pressure..do you hear the fuel pump click on right as you turn the key the first time or does it take it a minute
Old May 4, 2007 | 09:26 PM
iateshaggy's Avatar
Default Re: strange start up routine (lowered94accord)
would that trigger a cel? i haven't listened for the fuel pump yet btw.
Old May 5, 2007 | 05:09 AM
JimBlake's Avatar
Doesn't sound like you're describing a CEL. The lamps are supposed to come on for a couple seconds during their self-check routine. But it's NOT normal for the car to be unable to start during this 2 seconds.
Old May 5, 2007 | 06:45 AM
iateshaggy's Avatar
Default Re: strange start up routine (JimBlake)
great, now that we established that this isn't normal, does anyone know what would cause this? is it normal for the gear indicator to light the drive gear during this check?
Old May 5, 2007 | 06:56 AM
im confused at what your saying...you said earlier the check engine light went off...does it come back on or something or what?...and what exactly do you mean the gear indicator lights the drive gear..like theres a light around what gear your in or what? that doesnt make much sense
Old May 5, 2007 | 07:24 AM
iateshaggy's Avatar
when i start the car, i have to turn the key just to the on position. all the light turn on and off as normal but the cel stays on. then the green D4 (gear indicator) light turns on and then it and the cel turn off at the same time. as soon as they turn off i can start the car but not until then. sometimes this all happens in a moment, sometimes it takes a while.
i just want to know what is causing this. i've never had a car do this or even heard of this before. why can't my car break down like a normal car?
Old May 5, 2007 | 12:21 PM
gulfview's Avatar
It could the electrical portion of your ignition switch -- a fairly easy fix.
Old May 5, 2007 | 02:53 PM
iateshaggy's Avatar
Default Re: strange start up routine (gulfview)
how would that be related the gear indicator coming on and turning off?
Old May 5, 2007 | 03:25 PM
Rainy City's Avatar
You sure that just isn't the delay in your fuel pump priming?
Old May 5, 2007 | 07:35 PM
iateshaggy's Avatar
Default Re: strange start up routine (Rainy City)
would that make the drive light come on?
Old May 5, 2007 | 09:02 PM
it could...does your CEL come on when driving at all or after you start it? why dont you check to see if you have any check engine light codes..if not then Im clueless..its possible its the fuel pump or at least thats my first guess..or it could be something to do with the ignition switch as someone said before
Old May 6, 2007 | 09:08 AM
02 accord's Avatar
I'm assuming this is an automatic, and yes, it's normal for the D4 light to come on for a few seconds (in addition to P). As others said, it sounds like the fuel pump is the problem.
Old May 6, 2007 | 09:22 AM
iateshaggy's Avatar
Default Re: strange start up routine (02 accord)
wouldn't that cause the cel to come on while i'm driving?
JdmRex805
19
Nov 20, 2014 05:23 PM
xjm92x
Mar 28, 2011 06:18 PM
acidburn2k2
Aug 16, 2010 09:08 AM
Tizzakowack
Mar 8, 2009 02:37 PM
TodaSi
Aug 2, 2002 05:06 PM
