***No THermostat***
Old May 4, 2007 | 01:59 PM
Default ***No THermostat***
What up people......i swapped out my EF radiator for an EG one......i changed all the hoses.....and i come to find out i have no thermostat.....a few of my buddies reccomended i run the car like that....cause i cant tell my temp. at this time......so no thermostat and fan on all the time would keep it cool...WILL THIS DO ANY DAMAGE TO MY MOTOR......its a stock DOHC ZC.....Oh and my coolant temp sensor doesnt work...
Old May 4, 2007 | 02:10 PM
Default Re: ***No THermostat*** ("Jap*****")
HEEEEEEEEEEEEEEELP!
Old May 4, 2007 | 02:15 PM
dr_latino999's Avatar
Fix your coolant temperature sensor, and put a thermostat in. Running a motor too cold may not cause the immediate damage as running it too hot would, but it damages it non the less.
Old May 4, 2007 | 02:28 PM
Default Re: ***No THermostat*** (dr_latino999)
Do you know where that sensor is located........i found out its not workin cause of the CEL code. I heard its pretty pricey.....but meh im down to buy!
Old May 4, 2007 | 02:53 PM
Skipper75's Avatar
you can run with no thermostat..it just wont warm up properly..
may not run as good cause i think a couple sensors check water temp.
i may be wrong though
Old May 4, 2007 | 02:58 PM
89efDUSTY's Avatar
Default Re: ***No THermostat*** (Skipper75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "Jap*****" &raquo;</TD></TR><TR><TD CLASS="quote">Do you know where that sensor is located........i found out its not workin cause of the CEL code. I heard its pretty pricey.....but meh im down to buy! </TD></TR></TABLE> junkyard FTW seriously Honda if they have it will rape you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Fix your coolant temperature sensor, and put a thermostat in. Running a motor too cold may not cause the immediate damage as running it too hot would, but it damages it non the less.</TD></TR></TABLE> so true...i swapped for a half size, and sometimes if the fan doesn't turn on it gets way hot.
Old May 4, 2007 | 04:35 PM
Default Re: ***No THermostat*** (89efDUSTY)
Thanx for the info guys.......im also wondering where in the Engine is the sensor located?
Old May 4, 2007 | 04:56 PM
Suck my DX's Avatar
which sensor? the one for the fan switch?
there are two nipples on a plug by the single nipple oil pressure sender plug...pretty easy to see from the bottom of the car, but youll have to feel around for it from up top
Old May 4, 2007 | 05:49 PM
Default Re: ***No THermostat*** (Suck my DX)
the coolant temp. sensor.
Old May 5, 2007 | 10:52 AM
Suck my DX's Avatar
yeah that sensor is the one i just mentioned...the two nipples on the single plug by the oil pressure sender
Old May 5, 2007 | 10:54 AM
LilJonWask's Avatar
Ive heard running without a thermostat not only kills gas mileage, but also, there is a small amount of water vapor in the block that will never be perged if you run without a thermostat.
Old May 5, 2007 | 10:55 AM
.Manny.'s Avatar
Touching My Member
and running cool all the time will make you waste an assload of gas. the computer will take forever to go into closed loop. you will constantly run rich. its not fun
Old May 5, 2007 | 10:58 AM
Ermil's Avatar
Default Re: ***No THermostat*** (.Manny.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Manny. &raquo;</TD></TR><TR><TD CLASS="quote">and running cool all the time will make you waste an assload of gas. the computer will take forever to go into closed loop. you will constantly run rich. its not fun</TD></TR></TABLE>
But that's MAD tyte!
Old May 5, 2007 | 12:22 PM
cr-x-91's Avatar
like manny says...the will run in open loop and ur car will run rich.
TNight
Jul 17, 2014 01:20 PM
coolusername
Aug 10, 2007 03:52 AM
ek4d00r
Aug 1, 2005 04:12 PM
yellowturbo
Jan 7, 2004 02:44 PM
