Base timing jumper location on '99 Civic?
Old May 4, 2007 | 11:34 AM
Run Away's Avatar
Default Base timing jumper location on '99 Civic?
Hi there,
I'm hoping you can help me out with finding the base timing jumper on a '99 civic with a D16Y8, if there is one.
We just did a timing belt change and we're trying to verify if the timing is correct,
Mitchell on demand shows it under the glove box but we can't find anything. In fact I'm suprised an OBDII car has one.
I've been searching on here and all I can come up with are EG-related things.
Old May 4, 2007 | 11:43 AM
EE_Chris's Avatar
Default Re: Base timing jumper location on '99 Civic? (Run Away)
It's the same connector you jump to get the CEL to blink. If you look up by the glove box, there should be a green rubber 'cap' which is holding the 2-pin connector you're after.
Old May 4, 2007 | 11:50 AM
ekb16's Avatar
yea if i remember correctly the 2 pin connector is covered my a big green rubber thing
Run Away's Avatar
Default Re: Base timing jumper location on '99 Civic? (EE_Chris)
Thanks for the quick response.
I'm still not seeing this connector.
Is it on the left side (by the HVAC controls) or the right (by the dook/kickpanel)?
As soon as I can get a camera I'll take some pictures because there's 3 of us here an none of us see a green rubber plug.
There is one green connector with 5 wires going to it, it looks like it goes to something HVAC related. Obviously not it.
Old May 4, 2007 | 11:53 AM
Civicman86's Avatar
kick panel passenger side, take the green cover (actual plug is brown i think) off and use a wire to plug it.
Old Jun 5, 2007 | 08:21 AM
DodgeThisHemi's Avatar
Default Re: Base timing jumper location on '99 Civic? (Civicman86)
So doing a jumper... You mean take the two wire harness and make a wire to connect those two wires together?
Old Jun 5, 2007 | 08:31 AM
pdiggitydogg's Avatar
https://honda-tech.com/zerothread/1901557
pictures and location of jumper
Old Jun 7, 2007 | 06:20 PM
freeshot350's Avatar
Default Re: (pdiggitydogg)
pic must be from an eg cuz i cant find mine either 00 si plz help if anyone has pics
prplcivic94
Jul 26, 2010 07:10 AM
getpecked
Aug 27, 2007 05:02 PM
hatch4raceb16
Dec 28, 2003 09:35 AM
